31st Dec 2018, 6:14 pm | #1 |
Homebrew 811A grounded-grid linear amp.
I acquired this - for £5 - at a radio-rally [Harwell? Newbury? can't remember] a few years back.
It's a nicely-constructed single-band grounded-grid linear using an 811A as the business-end. Looking at the tuned-circuits and capacitors I'm guessing it's for 14MHz. Assuming that the 811A is still OK, from what I can work out it should be good for 200W PEP - the 1942 RCA "Guide for Transmitting Tubes" - http://www.nj7p.org/Manuals/PDFs/Tub...-gfat-1942.pdf says it is rated (ICAS) for 65 Watts plate dissipation. But it needs a power-supply. Sample circuit - from an ARRL book - here: www.qro.it/amp/schemi/pdf/68hb187.pdf I'm guessing I need at least 1Kv HT at 150mA or so - hence my thoughts are drifting towards a 250V isolating-transformer driving a classic Cockroft-Walton diode-capacitor quadrupler. These days, capacitors are cheap and semiconductor diodes have low forward-resistance so I can build a supply that will easily deal with high instantaneous current-demand. I'll be adding a fan, too! |
31st Dec 2018, 6:45 pm | #2 |
Re: Homebrew 811A grounded-grid linear amp.
I have used CW multipliers for HT on many occasions, they work a treat (great for multi HT 1920's valve radios that need various HTs), for this I would go both up (positive) and down (negative) at the same time, may as well use both halves of the cycle! A modern transformer will easily cope with a kV or so of DC on the secondary WRT earth. Huge 55-0-55 toroids are easy to find, only three times each way.
31st Dec 2018, 6:53 pm | #3 |
Going "up and down" might present a few issues in this case with biasing of the output-bottle though. I need its negative to be at chassis-potential (both DC and RF).
I'm also pondering using a "Panel transformer" - https://uk.rs-online.com/web/p/din-r...rmers/0504139/ in reverse feeding a simple fullwave doubler. I've done similar things in the past to get 1.5Kv at an amp or so, and the result was good enough for MoD. |
31st Dec 2018, 7:29 pm | #4 | |
31st Dec 2018, 7:41 pm | #5 |
That would work.
I'm currently figuring out the bias supply: It needs something up to -50V with a low source-impedance, so I'm thinking about a chain of Zeners and a 'backwards' LT-transformer fed from the heater circuit - that at least guarantees the availability of bias when the tube is 'lit'. For TX/RX switching, some designs shove a couple of hundred volts of -ve on the grid to turn the valve hard off, but that means the B+ rail soars away to the peak-voltage the unloaded transformer can deliver - which stresses the smoothing components something horrid. I'm minded to fit a TX/RX relay that simply removes power from the HT transformer primary on receive - and accept that there will probably be a big core-thump/dimming-of-the-lights when power is called-for. I can over-spec the HT rectifier diodes so they can happily handle a few 50Hz cycles of 10A or so when the relay closes. |
31st Dec 2018, 9:58 pm | #6 |
Nice looking amp chassis.
Amazing how compact a monoband amp can be.
1st Jan 2019, 11:25 am | #7 | |
Peter (G3PIJ) |
1st Jan 2019, 7:14 pm | #8 |
My understanding is that you need to supply a squib of adjustable-bias to set the standing current: while the 811A is generally used zero-bias, I intend to use this amp for both SSB and AM. When running in AM mode the static carrier shifts the working-point a bit and so additional bias can be used to throttle things back a bit.
How it will handle 'controlled carrier' AM (series-gate modulation) - where the resting carrier is pretty much cut-off in the gaps between syllables - will be interesting to see. I expect to have to treat that a lot more like SSB than conventional AM. |
1st Jan 2019, 9:42 pm | #9 | |
- Peter G3PIJ P.S. See Figure 3 at http://www.813am.qsl.br/artigos/line..._Amplifier.pdf Last edited by G3PIJpeter; 1st Jan 2019 at 10:01 pm. |
1st Jan 2019, 9:58 pm | #10 | |
And yes, batteries can be used too: I remember a 1960s RSGB-Handbook design which used a 22.5V hearing-aid battery and a PP3 to provide the bias. At least with batteries you know the bias will 'always' be there, which can't be said for power-supplies that use separate transformers/rectifiers for HT, LT and grid-bias. |
