4th Sep 2019, 2:11 pm | #1 |
Not a Henley Solon...
Having pulled this out from its hiding place in the garage and used it for the first time in anger (can't remember when/where I acquired it), I thought I'd put up a picture and perhaps entice a few other obscure makes to be treated likewise. This one is a "Vicsol" and runs at about 250W.
(The use was somewhat off topic- soldering a piece of 16g silverplated copper wire (vaguely topical- used for RF power coils) around the end of an angled steel pipe in the boost side pipework of a turbocharger to form a lip to stop it from blowing out of the rubber pipe clipped round it).
4th Sep 2019, 7:06 pm | #2 |
Re: Not a Henley Solon...
Apparently you can still buy bits for these. Though at £40 or so I'm not likely to bite!
Looks like a version is still available as an Antex ST25.
7th Sep 2019, 10:39 pm | #3 |
Reminds me of one we had on site in one TRS for jobs on the ends of submarine cables( where the inner was circa .5inch,from memory ,soldered to the PSF) , but which ended up being used more for in station work on those ( remember them ) sealed cans on 51 type equipment. We got fed up diagnosing faults to within the sealed can ( as far as we could,sending can off to see it returned with same fault . We found it simpler to open the can, replace the faulty component ,test it with the can off , find it fault free and reseal the can.
