3rd Apr 2020, 10:31 am | #1 |
Five valve T.R.F too much treble .
I have just finished constructing a power supply for this set , 120v HT 2 volt and 2x grid bias volts ,the set works fine but there is excessive treble , I am using a suitable output tx with the pm2a output valve, tried different transformers , adding a c across the primary helps ,but I think this is just masking the problem ,Any help appreciated.Mick.
3rd Apr 2020, 10:40 am | #2 |
Re: Five valve T.R.F to much treble .
Too much treble on MW. I would kill for that. Perhaps it is suffering from lack of bass.
3rd Apr 2020, 10:56 am | #3 |
Does it have transformer coupling in the audio stages? They're unlikely to let much LF audio through. Unless you want to start modifying the set to tailor the sound to suit your taste I would think you're stuck with it.
Find a "woolly" old loudspeaker perhaps?
3rd Apr 2020, 11:20 am | #4 | |
Adjust your HF roll off to your taste. Martin
BVWS Member |
3rd Apr 2020, 11:31 am | #5 |
Hi you really need to hear this on a hi fi speaker the treble it's piecing ,a quick update I found that a 100k resistor across the sec of the inter stage tx improves the sound to an acceptable level on a 8x5 bog standard spk, The PM2A I am using is a 5 pin for a bit more gain . I must say the set is very well behaved for a trf .Mick.
3rd Apr 2020, 11:44 am | #6 |
Re: Five valve T.R.F too much treble .
I guess that you're hearing the self- resonance of the coupling transformer - those vintage jobs did use a lot of wire to achieve enough primary inductance, leading to a high leakage inductance which would resonate with stray winding capacitance. Your load resistor is the appropriate fix to damp the resonance.
You may be a pioneer, being the first to feed the output of the circuit into a hi-fi speaker! Any speaker of the period probably benefited from the HF resonance correcting its natural treble rolloff. Martin
BVWS Member |
3rd Apr 2020, 11:53 am | #7 |
That looks like a half-decent elliptical speaker. And it has a doped centre cone to emphasise HF response!
Edward. |
3rd Apr 2020, 12:01 pm | #8 |
... and no baffle, which won't help the bass either.
3rd Apr 2020, 12:22 pm | #9 |
And 50 years between the radio and the speaker. J.
3rd Apr 2020, 12:54 pm | #10 |
3rd Apr 2020, 3:03 pm | #11 |
A 1920s radio would never have been connected to a hifi speaker, such a test serves no real purpose. And it would have been connected to a speaker with a much reduced treble response than your modern eliptical speaker, and probably had a better bass response too. That's your problem, it'd probably sound fine and authentic through a 1920s speaker, and that's what you should be trying it with. I appreciate that you probably don't have one, but I'm sure that's the problem nonetheless.
3rd Apr 2020, 7:38 pm | #12 |
O.K I do have several vintage speakers, but they were in the loft ,that's why I was using the 5x8 spk Update! it's now running on a 1930's spk and it still needs the damping resistor .cheers Mick.
