Old 7th Sep 2019, 6:38 pm   #21
ORAWA01
Default Re: MFJ Dummyload faulty?
Originally Posted by Jon_G4MDC View Post
Spec VSWR on that model is 1.3:1 so they are inside that.
Yes, it is 1.1:1 at 100W. I couldn't decipher that too. At 60 ohms, I would have thought SWR would be higher.
But then my meters, are they accurate? I am not sure
They are vintage meters but sturdy well made heavy ones.
OSKER SWR-200
I have two of them, and they were reading the same SWR and same power output.
ORAWA01 is offline
Old 7th Sep 2019, 6:54 pm   #22
Jon_G4MDC
Jon_G4MDC's Avatar
And there lies another story - you are looking at one frequency with some other factors thrown in - some the meter in use, some your connecting leads and then the TX is not a 50 Ohms source anyway.
MFJ and all the rest are fulfilling a need in the market. I just wish they would use larger boxes for their ATUs compared to the inductor diameters.
Jon_G4MDC is offline
Old 7th Sep 2019, 7:00 pm   #23
G6Tanuki
G6Tanuki's Avatar
MFJ was at one time said to stand for "Mighty Fine Junk".
I suspect your dummy-load may have been overcooked at some time.
At junk-sales/hamfests/rallies you come across Heath "Cantenna" dummy-loads - oil-cooled beasties built into what looks like a paint-can. These were designed for the US market where Kilowatt-capable ham radio stations were commonplace - so Cantennas can take quite a thrashing.
https://www.eham.net/reviews/detail/13123
My dummy-load-of-choice when I was designing juicy RF-stuff was a big grey-finned beastie about the size of a large load-of-bread, by "Aspen Electronics" - you occasionally see these at rallies etc and they still sell for 3-figure sums.
G6Tanuki is offline
Old 7th Sep 2019, 7:07 pm   #24
Jon_G4MDC
Jon_G4MDC's Avatar
The grey one that looked like a radiator for your house?
I think Bird made that...but Aspen were their agents.
Just spotted you said loaf of bread... too small.
Old 7th Sep 2019, 7:13 pm   #25
Radio Wrangler
Radio Wrangler's Avatar
Originally Posted by budkor22 View Post
It is square pillar shaped ones, I used them to restore 1940s all valve radiogram once, and leftovers from the work. Like this one in the link.
https://www.digikey.co.uk/product-de...kaApcREALw_wcB
Wirewound... pretty much useless at RF, I'm afraid.
Also, shunting the bad dummy load relies on the value of that dummy load being stable. If it's been overcooked, then that might be a problem. A changing load could cause a lot of confusion sometime in the future.
Radio Wrangler is offline
Old 7th Sep 2019, 7:34 pm   #26
G6Tanuki
G6Tanuki's Avatar
Mine wasn't the "heater radiator" type, it was more like the Bird 8135. It would take two-tone SSB to 1Kw for 30 seconds or so. I remember having two fan-heaters-set-to-cold-blow to cool it when doing intermodulation tests.
G6Tanuki is offline
Old 7th Sep 2019, 8:31 pm   #27
Jon_G4MDC
Jon_G4MDC's Avatar
Yes OK - I think the 8135 could have a meter head fitted at the front which was my most common encounter of it.
Most Bird stuff was no good for IM testing below the -30dBc or so of SSB specs. I used to hold them off by long reels of RG214 until they would not generate.
Intermodulation testing can have a thread of its own. Or a book.
Old 9th Sep 2019, 10:00 am   #28
ORAWA01
I ordered another dummyload MFJ 264. It is 1.5Kw rated, but I will never have occasion to use that power ever. Maximum 100W would be my usage for the dummyloads.
Hopefully it will have good spec not too far way from 50 ohms unlike the cursed MFJ 265B.
No, I am not a dummyload collector.
ORAWA01 is offline
Old 10th Sep 2019, 11:06 am   #29
Herald1360
Herald1360's Avatar
Not yet
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 11th Sep 2019, 7:55 am   #30
ORAWA01
Originally Posted by Herald1360 View Post
Not yet
My encounters with dummyloads had been always, buy cheap, buy three times case
ORAWA01 is offline
Old 11th Sep 2019, 4:34 pm   #31
ORAWA01
MFJ 264 arrived, and it is measuring 50.1 ohms.
Metal casing is substantially larger than the 260B, and well within spec. and 1.5 Kw rated. It seems more trusty and dependable dummy load, although more expensive.
ORAWA01 is offline
Old 19th Oct 2019, 3:38 am   #32
M3VUV51
Originally Posted by MrBungle View Post
If it’s MFJ it was probably broken when it came out of the factory like my ATU was. Not getting out was because there was a wire hanging off inside the tuner ffs.
Doesent mfj stand for "more fg junk"?
M3VUV51 is offline
Old 19th Oct 2019, 4:04 am   #33
Bazz4CQJ
Bazz4CQJ's Avatar
I think that MFJ gear is built down to a price. I own a 948 tuner, and the build quality is not very good. I've been over quite a lot of the joints and re-soldered them. Like other "budget" brands, I suspect that the build quality is very variable, so one 948 tuner or dummy load might be pretty much okay as it leaves the factory, while another might be not at all OK . All that being so, the ATU's do seem to have reasonably good reputation and anything better will certainly come at a significantly higher price.
B
Bazz4CQJ is online now
Old 19th Oct 2019, 10:41 am   #34
Restoration73
Restoration73's Avatar
A major error in the MFJ antenna tuner is the inductor rotary switch uses a break before
make wafer, encouraging arcing. I have repaired these with a make before break type.
Restoration73 is offline
Old 19th Oct 2019, 11:14 am   #35
ORAWA01
yup, I had a few MFJ ATUs and Antenna switches, and they feel a bit flimsy in build quality, but they work.
But when I open them up and see inside, I feel always that I paid too much for them.
20 - 30 year ago, they used to be real cheap, about 25-30 percent of the MIJ products, but now they are even more expensive than MIJ products.
It must be to do with the exchange rate of pounds vs. usd. But still they seem sell like hot cakes.
ORAWA01 is offline
