Old 1st Apr 2019, 10:04 am   #21
electronicskip
electronicskip's Avatar
Default Re: Rust removal from steel component on the cheap.
Originally Posted by M0FYA Andy View Post
By 'tin foil' I guess you mean aluminium foil?
Yes it was a roll of aluminium foil, he demonstrated it on a metal base of something he was restoring .
electronicskip is online now
Old 1st Apr 2019, 11:33 am   #22
M0FYA Andy
Do you think there was some chemical or electrolytic action, or did the foil just behave as an effective mechanical 'scrubbing brush'?
Andy
M0FYA Andy is online now
Old 2nd Apr 2019, 5:56 pm   #23
ColinTheAmpMan1
ColinTheAmpMan1's Avatar
Originally Posted by electronicskip View Post
Was watching American restoration the other night and the guy demonstrated a way to get rid of heavy surface rust by rubbing tin foil over the metal.
I have to say it actually worked the outcome was 1st class and looked like new.
This sounds weird to me. Was there any significance in the fact that this post was made on April 1st? Just asking....
Colin.
ColinTheAmpMan1 is offline
Old 3rd Apr 2019, 7:52 am   #24
kernowcam
I have used aluminiumfoil scrunched up to remove rust. its pretty nonabrasive. I believe it was for a chrome plated trim panel for a accordian with rust pitting.
kernowcam is offline
Old 3rd Apr 2019, 10:54 am   #25
HamishBoxer
HamishBoxer's Avatar
When I get around to trying it,I have some Hammerite Rust Removal Gel here.
HamishBoxer is offline
Old 3rd Apr 2019, 9:01 pm   #26
Bazz4CQJ
Bazz4CQJ's Avatar
Perhaps we should look at this from another angle. Rubbing down a rusty surface with aluminium foil will give you nice mixture of particles of rust and particles of aluminium and I suspect that some of you will now think of the term "Thermite". For those who don't know, Thermite is an extremely powerful pyrophoric mixture, consisting of powdered iron oxide and powdered aluminium which used with skill, can be used to either cut or weld large sections of steel, see https://www.youtube.com/watch?v=RXQnIgrXJd8.
Anyone trying this "rust removal technique" had best make sure there are no sources of ignition anywhere near! As iron oxide is so hard that it is used as an abrasive, and aluminium foil is more "soft as putty" ranking, this does not sound like a good rust removal strategy to me. Why not just use steel wool or stainless steel wool?
There's no 'magic electrolytic action' because there's no electrolyte!
B
Bazz4CQJ is offline
Old 3rd Apr 2019, 11:40 pm   #27
m0cemdave
I'm sure Thermite is very hard to ignite. When we made it at school (yes, such things were allowed in those days) we had to use a piece of burning Magnesium strip to start it off.
m0cemdave is offline
Old 4th Apr 2019, 12:03 am   #28
Bazz4CQJ
Bazz4CQJ's Avatar
Maybe so. I don't recall getting to 'play' with Thermite at school . However, we did some interesting stuff with sodium chlorate weedkiller
in the days before it had inhibitor added to it, and a death or two was only narrowly avoided
B
Bazz4CQJ is offline
Old 4th Apr 2019, 11:54 am   #29
ColinTheAmpMan1
B
I agree with a lot of this, but I feel I should repeat my statement that rust isn't just iron oxide, it is ferroso-ferric oxide and probably contains some other iron compounds such as hydroxides and carbonates. I think it might make a pretty poor Thermite mixture. The Royal Society of Chemistry web-site says that iron(III) oxide (ferric oxide) should be used. I should add that while I have made Thermite and ignited it in the same manner as m0cemdave stated, I have no direct experience of making Thermite by rubbing rusty metal with aluminium foil. I might be talking nonsense.
Colin.
Old 13th May 2019, 1:47 pm   #30
BulgingCap
I agree with Kalee: Oxalic acid, sold here as a concrete and patio cleaner in a granular form, is very cheap and superb. It needs no heating and the steel item can be left in the solution indefinitely without ill effect.
I keep the solution in old 2L plastic milk bottles, and pour it into whatever plastic container best suits the shape of the item to be cleaned. It can be reused many times until it loses its potency.
The rust disappears completely leaving a matt grey surface.
It hurts like heck in a cut !!
BC
BulgingCap is offline
Old 13th May 2019, 1:56 pm   #31
BulgingCap
The local old boys recommend molasses for rust removal. It is readily available because sugar cane is grown in Oz. It seems to be a bit fierce and will eat away the steel if left too long. I have just searched out a story of a chap who dug a big hole, lined it with black plastic, and put a 1913 Cadillac car chassis and springs etc into a molasses solution. The narrator recalls that his elderly friend forgot about it for a while, and when he checked again the chassis had gone !
BC
Old 20th May 2019, 10:43 am   #32
nicam49
All the above makes absorbing reading, is there any way of making any of the above (apart from the molasses) thixotropic so it can be applied to a vertical surface without dripping off?
nicam49 is offline
Old 20th May 2019, 2:34 pm   #33
GMB
GMB's Avatar
A clue to how the original mixture works is that hydrogen peroxide has to be stabilised and tends to contain things like phosphoric acid.
(Something that people who used it to whiten teeth discovered the hard way!)
GMB is offline
Old 20th May 2019, 10:59 pm   #34
LXSTEIN45
Electrolysis works very well
ID:	183505   Click image for larger version
ID:	183506   Click image for larger version
ID:	183507   Click image for larger version
ID:	183508   Click image for larger version
LXSTEIN45 is offline
Old 20th May 2019, 11:00 pm   #35
LXSTEIN45
more pics...
ID:	183510   Click image for larger version
ID:	183511   Click image for larger version
ID:	183512   Click image for larger version
ID:	183513   Click image for larger version
Old 20th May 2019, 11:02 pm   #36
LXSTEIN45
Just need to fill the pitting, and have finally confirmed the original colour as a sickly green, so after getting a photo sample from Pleasley museum I will finish this project!
ID:	183515   Click image for larger version
Old 20th May 2019, 11:16 pm   #37
GMB
GMB's Avatar
The electrolysis method can work well, but be aware that the result is said to re-rust very quickly unless painted without delay.
GMB is offline
Old 21st May 2019, 7:10 am   #38
trh01uk
trh01uk's Avatar
Yes, it looks very effective. Can I have a description of what exactly you are doing? Electrolyte? What is the other electrode made of?
Richard
trh01uk is offline
Old 21st May 2019, 9:44 am   #39
GMB
GMB's Avatar
The recommended electrolyte is washing soda (sodium carbonate). Do not be tempted to use common salt as this will promote re-rusting very well indeed.
When I tried this technique I used iron as the other electrode on the grounds that I didn't want any other metal going into solution, but it gets messy as it oxidises and reduces the current. I suspect carbon would be best, or gold/platinum of course! Don't use copper or you will eventually end up copper plating the object.
GMB is offline
Old 21st May 2019, 11:56 am   #40
joebog1
BC
I didn't stick my nose in until now!
REAL rust, like car parts or tractor components? Use Molasses.
DOES not eat steel, JUST the oxide bits. I haven't tried it on screws from a 3 gang tuning condenser/capacitor, but it sure works on motorcycle parts, car parts, (even rusting sills) nuts n bolts.
I think what I am saying is its probably MORE suitable to " big bits" rather than smearing it over an 18 valve communication receiver chassis.
Thanks aussie.
Joe
joebog1 is offline
