Old 2nd Oct 2019, 1:43 pm   #1
avocollector
Default Disassembly of Sanyo M4100K boombox
Does anyone know how to get the handle off this model radio cassette player? The handle in place seems to be holding the back on yet the pins apparently holding in the handle will not pop out - think they might be screwed in or something. Thanks
avocollector is offline
Old 2nd Oct 2019, 1:54 pm   #2
Nickthedentist
Nickthedentist's Avatar
Default Re: Dissembly of Sanyo M4100K boombox
Sorry I can't help specifically, but it's rare in units of this era for the handle to have to be removed before splitting the cabinet. Normally, it's pretty permanently attached.
Could you post some photos showing us the actual problem you're describing please?
Nick.
Nickthedentist is online now
Old 2nd Oct 2019, 1:55 pm   #3
paulsherwin
paulsherwin's Avatar
It's sometimes easy to miss a retaining screw.
paulsherwin is offline
Old 2nd Oct 2019, 2:08 pm   #4
Nickthedentist
Yes, typical hidden ones are in the battery compartment, in the cassette well, or under push-on knobs.
Old 4th Oct 2019, 6:26 pm   #5
avocollector
Here are some pics of the boombox and the troublesome handle - I've found all the other screws, pulled off the knobs etc and still no joy
ID:	191294   Click image for larger version
ID:	191295   Click image for larger version
ID:	191296   Click image for larger version
Old 4th Oct 2019, 6:27 pm   #6
avocollector
Also meant to say thanks to everybody for their suggestions. The pins holding in the handle will NOT pry out or unscrew with reasonable force - I'm thinking they must be screwed or held in some way.
Old 4th Oct 2019, 7:40 pm   #7
Reelman
Reelman's Avatar
I presume that to remove the handle you are trying to separate the case? By gently trying to prise around the split of the case you should find a more resistant part that can be further investigated for hidden screws.
However sometimes a thin piece of felt is glued to one half of the case to deaden vibration where it meets the other half. Over the years the glue migrates through the felt until it effectively glues the case together. A little heat may help to soften the glue and then have the courage to force it!
Good luck with it.
Peter
Reelman is online now
Old 5th Oct 2019, 5:18 am   #8
avocollector
Good luck with it.
Peter
Thanks - that's what I tried in picture No 1 above - the case is separated progressively towards the bottom LH end of the pic - and you can see the separation leads and narrows towards the handle fixture at the top RH. It's more firmly fixed than I really want to put any pressure on. I assume there is some 'trick' to opening it but really cannot figure it out.
