16th May 2018, 10:04 pm | #1 |
Identify part
What is this part kss6w ?
16th May 2018, 10:04 pm | #2 |
Re: Identify part
16th May 2018, 10:06 pm | #3 |
Re: Identify part
It's a thermistor, I believe.
16th May 2018, 10:46 pm | #4 |
Re: Identify part
560ohm thermistor i think.
17th May 2018, 12:22 am | #5 |
No Longer a Member
Re: Identify part
I realize that you didn't ask how it worked, but in trying to figure out what an unknown part is, it is often instructive to see what it is supposed to be doing or might be doing.
As you can see the part is placed between the bases of two output transistors. As the transistors heat up, their base-emitter voltage drops, something like -2.1mV/DegC and their base current increases for any fixed applied base voltage and so does their collector current increase. If this is not compensated for there is a risk of thermal runaway and heat damage to the transistors, though the transistor emitter resistors also help by dropping more voltage and reducing the base current through DC negative feedback as the currents increase with heating.But they are not enough on their own to thermally stabilize the transistors. In any case it means that the part in question must be a negative temperature coefficient resistor (as noted called a Thermistor). It lowers its resistance (and therefore the voltage drop across it) as its heated, lowering the base currents to compensate the transistor's increase in base current with heating. Ideally that thermistor should be thermally coupled/bonded to the transistor's heat sink (if there is one) but some manufacturers for low power output stages just put them nearby to the output transistors on the pcb. Often you will see one diode and resistor or two diodes used instead of a thermistor in this circuit position because the diode's voltage drop decreases with heating, much like the transistor's base-emitter junction, or even a transistor and potentiometer wired as a vBE multiplier to adjust the inter-base voltage and the transistor's quiescent collector current and thermally stabilize it. |
