Old 20th Jul 2017, 11:34 am   #1
Deleyeme7777
Thumbs up Update on Ekco A22 reproduction radio.
Hi all, some may remember that I was able to reproduce a green AD65 outer casing in threads some time ago, well I said that I was going to attempt an Ekco A22 cabinet in the future, well it's well on the way and I have one not quite finished as yet and when it is I will post a picture or two, plan is to make a red, then a green, and possibly a white, it's been a long term project, but it's all coming together quite nice
Deleyeme7777 is offline
Old 20th Jul 2017, 12:31 pm   #2
David G4EBT
David G4EBT's Avatar
Default Re: Update on ekco a22 reproduction radio
Looking forward to the end result - the AD65 was spectacular!
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline
Old 20th Jul 2017, 4:30 pm   #3
Lloyd 1985
Lloyd 1985's Avatar
Default Re: Update on Ekco A22 reproduction radio.
This sounds most interesting! I'd love to have a go myself, I've got a spare A22 chassis in my storage unit gathering dust...
Lloyd
Lloyd 1985 is offline
Old 21st Jul 2017, 10:04 am   #4
Deleyeme7777
Well blow that dust off of it Lloyd and send it over to me, o could use one
Old 21st Jul 2017, 11:17 pm   #5
Deleyeme7777
Sorry David, almost forgot to thank you for the kind remarks, glad you liked the AD65
Old 19th Aug 2017, 6:13 am   #6
Deleyeme7777
Default
I have been able to reproduce a couple of cabinets, for the Ekco A22 one in a Red colour and one in the Green colour, not quite finished still needs final polish and a good clean up
ID:	148101   Click image for larger version
Old 19th Aug 2017, 8:58 am   #7
David G4EBT
Nothing short of stunning!
Can't begin to imagine the work that went into creating the mould and casting the cabinet.
(Presumably male and female moulds too?).
Just need to create the innards now!
It gladdens the heart to see such skill!
David.
BVWS Member.
Old 19th Aug 2017, 9:42 am   #8
MurphyNut
MurphyNut's Avatar
Fantastic reproductions, what's the material, how did you go about making the mould? This is very interesting coming from an avid Bakelite collector.
Clive
MurphyNut is offline
Old 19th Aug 2017, 10:26 am   #9
Kevin Hoyland
Hello.
Outstanding work.
Kevin.
Kevin Hoyland is offline
Old 19th Aug 2017, 12:15 pm   #10
Tractionist
Absolutely ...... awesome! Bravo !!
Red to red, black to black. Throw the switch and stand well back!
Tractionist is offline
Old 19th Aug 2017, 12:24 pm   #11
Reelman
Reelman's Avatar
Very, very impressive indeed! There would certainly be a market for those cabinets if you could make enough to sell.
Peter
Reelman is offline
Old 19th Aug 2017, 8:12 pm   #12
Lloyd 1985
Lloyd 1985's Avatar
WOW!!!
They look absolutely stunning! I'll have to see if I can find that old chassis that's lurking in a corner of the storage unit...
Lloyd
Old 20th Aug 2017, 5:49 am   #13
Deleyeme7777
Thanks for the positive replies , yes quite a few months to make moulds and the same with the cases, as with the exterior, the case interior has the same detail throughout , it has been extreamly time consuming and I have invested a sum of money into this project as you can imagine ,I have a chassis that I purchased a while ago so when the cabinets are completely finished I will fit to one of them, just not sure which one yet.. I will look for another chassis or two, as I would like a white one as well..I will post the end result, front ..side ..and rear pics
Old 20th Aug 2017, 10:02 am   #14
Tractionist
Next ..... the knobs? !!!!!
Old 21st Aug 2017, 11:00 am   #15
Deleyeme7777
No, the knobs ate already made, did them first, that was the easy part, I will post pics if anyone os interested
Old 21st Aug 2017, 12:44 pm   #16
Tractionist
Dinkum !!!
Old 23rd Aug 2017, 3:35 pm   #17
Retired
Retired's Avatar
What a fantastic result; you can be truly proud of your achievement; I'm most impressed. It's been asked before but what is the material; is it plastic injection?
Kind regards, Col.
Retired is offline
Old 23rd Aug 2017, 6:08 pm   #18
neil24-7
Very nice job indeed well done.
I'll have a guess at a 2 part RTV silicone mould suspended in a fibreglass support mould and pigmented resin?
Cheers Neil
neil24-7 is offline
Old 25th Aug 2017, 8:25 am   #19
Deleyeme7777
No it's not injected, heat, pressure moulds are in multiple pieces and I use a combination of steel ,stone, plaster, wood, aluminium , tried many things and doing it this way works for me, I am sure others have tried and might have a better way but with the shapes of some radios and being able to reuse the mould, it works for me, the hard work starts when it out of the moulds, takes between 4-6 weeks, the mould for this took me around 7-10 months with all of the planning to do as well, not really cost effective, but it's passion and not always about the money, I have swapped other radio cases for international radios in the past, and probably loose money but my time gets taken up on planning and working out future moulds so don't have the time to chase hard to come by radios
Old 25th Aug 2017, 9:43 am   #20
Mach One
Mach One's Avatar
I'm not at all aware of the technology, but I suppose that such reproduction cabinets could be made with 3D printing?
Mach One is offline
