10th Dec 2006, 4:29 pm | #1 |
Info on Mechanical exchanges
Hi All,
Well, it had to happen eventually - I fancy a go at building a small(ish) exchange, so seeing as I know diddly about old exchange technology, I would like to gain more information! Any suggestions as to the sort of literature I should be reading up on? Offers of parts also gratefully recieved! Cheers Sean Men in white coats are looming.......
10th Dec 2006, 4:42 pm | #2 |
Re: Info on Mechanical exchanges
Sean,
the book(s) to look for, are the two volume set "Telephony" by Atkinson. They cover the full range of telephone signalling, switching, and power plant up to about 1960, and will give you all the basic information, and then add in the complex stuff (trunking etc.). Your local library may have a set, but you can borrow mine if you get stuck. Jim. |
10th Dec 2006, 5:23 pm | #3 |
Thanks Jim,
Found some on Abe books...... I feel a christmas present coming on! Cheers Sean
10th Dec 2006, 7:15 pm | #4 |
I have a small mechanical Telephone exchange I built about 20 years ago when the XYL decided she wouldn't sit in the hall in front of a piece of hardboard loaded with jack sockets routing the Kids calls from their bedrooms to the playhouse, garage and my Shack.. Meany!!
It was based on a design in Wireless World dated August 1980 and used only miniature plug in relays to give 10 lines I think. I modified it to use a small Uniselector. It's been running 24/7 since I built it. Only problem it has is periodically losing audio across the transmission bridge due to dirty relay contacts. It really needs some DC wetting. I wasn't as dilligent then with the paperwork as I am now and only have a few dog eared bits of paper with scrappy drawings...Somewhere!! Denis |
10th Dec 2006, 7:19 pm | #5 |
Hi Denis,
You seem to be faring better than I am....... SWMBO has mentioned unspeakable things involving sharp objects when I showed a picture of a Strowger exchange..... Still, feeling brave (and having a family already) I think I will continue in this quest! Cheers Sean
10th Dec 2006, 7:19 pm | #6 |
Denis,
if you find the drawings, that sounds like an interesting little project. Jim. |
10th Dec 2006, 7:33 pm | #7 |
Just a thought.....
Sean, one of those ex-SSR 5G relay / switching boxes might make a good basis for a simple relay type exchange - single digit dialling and the like (or 2 digit -strip the first digit unless it corresponds to an outside call. It might even be possible to convert one of the register units, which will give you a small relay/uniselector exchange, in a a box about 2' x 2' x 1'. There were a lot of small PAX's (private auto exchange - not connected to the PO network) based on that technology, and of a similar size. Jim. |
10th Dec 2006, 9:17 pm | #8 |
It may be worth joining the Telecoms heritage group http://www.thg.org.uk/ as there is a wealth of information amongst it's members regarding all manners of telecoms equipment and exchanges
Regards Andrew |
11th Dec 2006, 1:31 pm | #9 |
Just spotted this thread.
Have a look at Beery's website. I know that he has been building a small mechanical exchange for a while, and it's fairly well documented on his website. You may be able to PM him to get more info / help with this. Alan. |
11th Dec 2006, 2:01 pm | #10 |
There must be a fair amount of old Strowger exchange kit in the hands of enthusiasts. I know at least one person who acquired signifcant amounts of Strowger kit when old PABXs were being scrapped. I can't imagine that there's any Strowger left in commercial service in the UK. I'm not counting installations such at the UAX at Amberley Museum which are maintained by enthusiasts.
The THG is surely the right place to find out more. |
11th Dec 2006, 4:05 pm | #11 |
ok, Have joined THG - Madness is getting closer - Now just need to add another Shed in the garden......
I think a recce of a few old sites in this area might be a good idea...... Cheers Sean
11th Dec 2006, 5:00 pm | #12 |
Sean, we're starting to get really worried about you. We often had our doubts but now you've become a moderator and joined the THG.
11th Dec 2006, 8:13 pm | #13 |
Hmm, web trawling draws me to having a go at UAX12 - anyone got any more specific info, or sources of parts to play with?
Cheers Sean
11th Dec 2006, 8:33 pm | #14 |
Sean,
all the UAX series are described (with diagrams) in "Telephony". Jim. |
11th Dec 2006, 8:41 pm | #15 |
Cool! - will be adding books to Xmas list!
Time for parts shopping...... Cheers Sean
11th Dec 2006, 8:43 pm | #16 |
Sean, when you come to collect the Tek manuals you are welcome to borrow my copies of Atkinson's Telephony until you find your own.
11th Dec 2006, 8:53 pm | #17 |
I doubt that there is much UAX equipment left in the wild, but look out for small unkempt village exchange buildings on your travels (Telephony covers the standard buildings as well....). You may get lucky, as some of these buildings were either abandoned, or the equipment content reduced to a couple of wall mount boxes at the end of the Strowger era. I missed a UAX by about 3 weeks some years ago - the building was being converted, and the equipment went in the skip
Jim. |
12th Dec 2006, 8:10 pm | #18 |
Well, lots of usefull stuff about - My local library is getting Volume 2 of telephony for me - Vol 1 not available!
I think a small PABX might be the best way to start (well according to some expert nutcases!) Have even found a likeminded individual here in Hitchin! Cheers Sean
12th Dec 2006, 9:21 pm | #19 | |
Jim. Last edited by Dave Moll; 27th Jun 2007 at 4:33 pm. Reason: correct for username change in quote |
12th Dec 2006, 9:29 pm | #20 |
Hi Sean, if you want I can photocopy the relavant pages on the UAX12 from Telephony. I think you sold me my copies anyway...
Sam
Can he lead a Normal life, Doctor? No, he will be ... an Engineer. |
