Old 16th Oct 2012, 9:46 am   #1
robjkmannering
Default Transistor used as bias diode
During my recent radiogram repair, I encountered a transistor in the dc coupled amp with the base emitter junction used as a diode.
This I assumed to be for biasing. As the transistor tested okay I did not replace it.
The transistor is a 2SC1129 wich is listed for vhf use.
As the amp now uses BC558s ect. I wondered if I need to change the bias 'diode' so that it will have the same temperature characteristics as the rest of the transistors used or will it have little difference?
Thanks,
Rob
robjkmannering is offline
Old 16th Oct 2012, 10:44 am   #2
julie_m
Default Re: Transistor used as bias diode
What you have here is one of those "it shouldn't work, but it probably will if you don't tell anybody" situations.
Try warming the amplifier board with a hairdrier and cooling it with freezer spray, and listening out for any obvious distortion.
julie_m is offline
Old 16th Oct 2012, 10:58 am   #3
G8HQP Dave
Why shouldn't it work? All BJTs follow the Ebers-Moll model fairly accurately.
G8HQP Dave is offline
Old 16th Oct 2012, 5:04 pm   #4
AC/HL
AC/HL's Avatar
Transistors were often used in place of diodes for stabilisation. I suspect that the 2SC device would not be the original one from a Thorn radiogram, but should be as good as any other silicon junction. It's only the thermal characteristics that are being harnessed.
AC/HL is offline
Old 16th Oct 2012, 5:15 pm   #5
kalee20
As long as you're replacing small-signal silicon with small-signal silicon, I'd expect it to work, as G8HQP Dave and AC/HL have observed.
If you were replacing with a 100A power transistor, then you may not get quite enough bias voltage generated. But that's not the case.
As it's just used as a two-terminal device, you could even swap between NPN and PNP, with polarity reversal.
kalee20 is offline
Old 16th Oct 2012, 6:25 pm   #6
May well be used because it's easier to 'clamp' a transsitor case ot the heatsink rater than a diode.
Old 16th Oct 2012, 7:23 pm   #7
G6Tanuki
G6Tanuki's Avatar
Indeed: I'm prepared to bet that the quality of the thermal-bond between the 'bias sensing' transistor/diode is rather more important than the precise characteristics of the transistor/diode itself.
I have memories of a Redifon-designed HF linear amplifier which had a couple of dirty great stud-mount power rectifiers fitted on the heatsink right between the output-transistor quad. Along with two OC35 transistors passing a couple of amps, they worked quite well to stabilise the bias up to heatsink-temperatures around 80 Centigrade.
G6Tanuki is offline
Old 16th Oct 2012, 9:03 pm   #8
robjkmannering
In this case, the transistor is not mounted on a heatsink, the ouput pairs have individual aluminium fins. The transiator does not even sit close to another semi-conductor so heat transfer is not an issue.
Rob
