Old 19th Jan 2019, 8:32 pm   #1
G6Tanuki
G6Tanuki's Avatar
Default Pye P75: How not to do it.
A decade back some friends bought themselves a house; it came with a horrible late-90s-style kitchen, all light-walnut wood-veneer and MDF. So traumatically early-Britpop it just had to go!
The Pye P75 that had sat on a shelf in this old monstrosity got gifted to me, the 'new' kitchen having been equipped with a Bose SoundDock so they could play music from their iPhones.
I only recently got round to looking at the P75; it had been unused for 10 years. Replaced the old figure-of-8 single-insulated mains lead with something modern, and pre-emptively replaced a few known-weakness capacitors. First-sound waa fine - OK, a bit deaf but a replacement ECH42 solved that. The big problem was a persistent background audio-crackle.
OK, so the EL41 is known to be a valve that has issues. Hard-wiring its grid to ground didn't stop the crackle. Replacing the EL41 with a 5KOhm resistor from anode-to-cathode didn't stop it either! There was another noise-beast to slay.
Testing pointed at the output-transformer having 'internal issues' - so I grabbed a similar-spec transformer from a scrap radio and fitted it: Joy! Lots of audio and no crackles!
So I dragged-out the original output-transformer and fitted the one from the scrap-set in its place. I only needed to drill a single mounting hole in the P75's chassis to make this substitution, because the substitute-transformer was about half an inch longer.
But - what's this? utterly-feeble audio and lots of distortion!
Get out the 'scope; there's not much voltage-swing showing on the EL41's anode. Swap-in a new EL41 - no difference.
Drink Gin-and-Tonics, go to bed.
Wake up the next morning, drink coffee, get enlightened! I'd wired the primary of the output-transformer wrong! It's got a hum-bucking winding - I'd connected the hum-bucking winding to the poor EL41's anode, which explains the pathetic audio...
Rewire, and - oh, happiness! TalkSport on MW is now really punchy and full of volume!
G6Tanuki is offline
Old 19th Jan 2019, 9:28 pm   #2
snowman_al
snowman_al's Avatar
Default Re: Pye P75: How not to do it.
Are you sure the sequence is correctly described?
Maybe the G&Ts came before the fitting of the opt...
snowman_al is offline
