15th Jan 2019, 4:12 pm | #1 |
Philips N2229AV cassette player
Hi I have a loose red wire on the transformer on my Philips N2229AV cassette player. It comes from the voltage selector switch, but I can't tell which pin it has broken off from on the back of the transformer. There are 3 pins, on the back of the transformer, 1 with a white wire, 1 with a red wire and 1 with a brown wire.
Thanks anyone. Last edited by AC/HL; 15th Jan 2019 at 4:19 pm. Reason: Images uploaded |
15th Jan 2019, 4:24 pm | #2 |
Re: Philips N2229AV cassette player
I'd suggest that it comes from where it's laying naturally. It's solid wire, and may have been scored when stripped. Vibration has taken it's course, unless it has been disturbed?
18th Jan 2019, 3:41 pm | #3 |
Hi, the transformer fell out when I tipped it up the get the spring out, that was when the wire came off.
19th Jan 2019, 4:07 am | #4 | |
What spring ?
When I die, please don't let my Wife sell my collection for the amount I told her I paid for it! |
19th Jan 2019, 4:10 pm | #5 |
Well, I'd think that falling out qualifies as being disturbed, presumably the chassis not the transformer itself! From those photos it still looks the same to me though.
20th Jan 2019, 8:45 am | #6 |
There was spring loose inside, when I tipped it over to get it out, the transformer came out and the wire came off. There are 2 places it could have come from, the post with the Red cable joining it or the Brown. Should I guess?
20th Jan 2019, 3:26 pm | #7 |
Ah. Not the red in photo 1, in that case it may be a tag out of view of either photo. It's unlikely that two wires go to the same tag, and as it's the mains wiring don't just guess!
Ease the transformer out and look for a tag with solder, but no wire attached. If you're not sure take more photos. The transformer wouldn't just fall out however, there looks to be some damage around the mains socket? |
23rd Jan 2019, 5:15 pm | #8 |
Thanks Bill, following on from your advice to look elsewhere, there is a blob of solder with no wire attached, on the battery compartment terminal. I can't tell if the wire would have come from there, however there is only 1 black wire coming from the batteries, this wire then would complete the circuit, would it go to the voltage selector switch?
24th Jan 2019, 6:37 pm | #9 |
That sounds reasonable, there should of course be two. Photo 2 now appears to be a switch to disconnect the batteries when a mains lead is plugged in, rather than anything to do with the mains. If so, reconnect the wire, but don't plug a mains lead in until you've confirmed that it works on batteries. A bit awkward working without a circuit diagram, and only two photos for evidence!
