Old 2nd Jan 2019, 9:29 pm   #1
shirely
Default Ferguson Videostar 3V43 - load motor drives hard on power-up
I have an old Fergie V/Star 3V43 which drives the loading motor hard one way on power-up.
The eject mechanism is in the ejected mode but the guides are fully laced up.
If I manually un-lace the mech & power up, the loading motor immediately loads the guides up to the max point and continues to turn until auto-power-off.
It doesn't appear to have a conventional mode switch but used what looks like optical sensors - which ive cleaned.
Im stuck!
Any ideas?
BIG thank you!
shirely is offline
Old 2nd Jan 2019, 10:12 pm   #2
jayceebee
jayceebee's Avatar
Default Re: Ferguson Videostar 3V43 - load motor drives hard on power-up
Hi and welcome. This is unusual as the motor should try to return the deck to unload mode then eject if it's not already there when applying power. If it's not something silly like the plug to the loading motor accidentally reversed then a possible cause may be a missing voltage supply somewhere due to a faulty CP, a fuse which look like a transistor with two legs. A manual is pretty essential here but I haven't been able to find one for this model.
John.
jayceebee is offline
Old 3rd Jan 2019, 2:56 am   #3
ben
ben's Avatar
I had this exact problem with a JVC HRD140, these decks don't have a mode switch per se but an optical sensor, think that had failed on mine. Will try and find my notes.
Regards,
Ben.
ben is online now
Old 4th Jan 2019, 8:27 pm   #4
shirely
BIG thank-you lads - i will have a look around for an O/C CP & check the optical sensor.
Its worth a look.
shirely is offline
