1st Jan 2019, 4:27 pm | #1 | |
Modifications to equipment earthing arrangements.
Cheers, GJ
http://www.ampregen.com |
1st Jan 2019, 5:35 pm | #2 |
Re: Modifications to equipment earthing arrangements.
Good practice inside equipment is to keep mains primary connections and wiring away from low voltage/ customer accessible things, to bundle wiring separately. The idea is to make it so that anything which could bridge mains connections to customer accessible connections must connect to earthed metalwork, shielding etc first and pull the fuse before anything dangerous could happen.
Hence the use of safety screens in transformers, grounding cores etc. David
1st Jan 2019, 8:13 pm | #3 | ||
Of course what you do to your own equipment FOR YOUR OWN USE is up to you. Just don't pass it on to someone else. It is for this reason that I don't agree with earthing the speaker grille of DAC90A radio's....some offered for sale have been so modified.
1st Jan 2019, 8:33 pm | #4 |
Thanks R, I thought it hadn't been tested in the courts. It's a shame because I'm sure you're right - folks are put off making simple safety improvements. Instead they decide to protect themselves against a theoretical legal risk by leaving their customers and their family and friends exposed to a real physical one. I can well understand why they do it. It's the same (legal) reason that in some countries off-duty doctors walk past people having heart attacks. But my conscience would struggle with it.
Cheers, GJ
1st Jan 2019, 8:37 pm | #5 |
This is interesting and I would like to understand further the consequences of adding a 3 core mains lead to a vintage Record Player or Radio (AC only).
Do I understand correctly that if it is to remain in your possession it’s ok to do such a thing, but if you are going to sell it on its not? This is a tricky subject, and I would like clarification if that is possible. Cheers John |
1st Jan 2019, 8:55 pm | #6 |
I believe you can do whatever you like to your own stuff. The only consequence might be that your insurance company could refuse to pay out if you did something which resulted in a death or injury or damage to property.
Whether you can sell a modified item or not depends on whether the item is 'safe' or not and whether it complies with the 'required' regulations. What 'safe' means and which regulations are 'required' is a matter for the courts and it seems that there is little definitive information about this. There are some quite strong opinions though. Cheers, GJ
1st Jan 2019, 9:37 pm | #7 |
I must admit that with the amount of dangerous NEW goods coming into the UK through 'legitimate' sources i don't ever worry that a well thought out and executed safety related mod. will bring an appliance into a different category that has different rules. Life's too short (not trying to be witty there.) It's never possible to envisage the use- or misuse- to which a future owner may subject an appliance, in any case.
I was once working in a depot where the tiled floor was sopping wet from rain soaked shoes marching in and out. I grabbed a mop and removed as much of it as was possible, at which point an 'Ardener' (our old office term for a possessor of a mouth that should be mainly shut) piped up that commencing to clean the floor made me (or the company) liable for any slips and trips that occurred if it were still slippery after i had finished. I can't remember what i said but it was probably along the lines of 'just get the other mop and start helping'. Dave |
1st Jan 2019, 9:49 pm | #8 |
It's the word 'safe'. Even as an approved test lab, we cannot say that equipment is 'safe'. However we CAN say that equipment tested complies with the standard (whatever standard) we have tested it to at the time of testing.
Seriously....these arguments/discussions can go on forever and someone will always disagree. That is why standards were devised....and some people disagree with those as well.......!
1st Jan 2019, 9:54 pm | #9 | ||
That is why the general consensus of opinion is to leave it as the original design.
1st Jan 2019, 10:32 pm | #10 |
Thank you all for your replies and opinions.
I note that there are a number of outlets selling vintage equipment with comments such as “ brought up to today’s standards with new 3 core mains lead with 3 amp fuse etc etc...” One last thought why can’t a well made vintage Record Player with a Mains transformer be safe? Cheers John |
1st Jan 2019, 10:39 pm | #11 | |||
Suppose, like many, you do repairs for free for friends and relatives. You aren't selling it, or "selling" a repair. How do you stand then? |
1st Jan 2019, 10:45 pm | #12 | |
Some things are more safe or less safe than others. It depends on how much money you're prepared to spend without making the product unaffordable and what safety features you can incorporate without impairing functionality too much.
1st Jan 2019, 11:38 pm | #13 | |
That record player would definitely be harmful if swallowed... it's simply too big. It would harm someone if it was chucked in while they were having a bath and it was still plugged in. Dropped from an aeroplane.... With care, it can be made to an acceptable level of safety. Not perfect, but as good as can reasonably achieved.... and that merely swaps one weasel-word for another. "safe enough" isn't defined ANYWHERE. Mrs Contusion is not going to accept that the record player which killed 'er 'orace was safe enough. If it was safe enough, it wouldn't have killed 'im! The question comes down to what your lawyers could convince a court with. Being able to stand up and say that said record player met all the required safety standards laid down by government bodies. You have the test house results documents here along with copies of the then current calibration certificates for the test equipment used, and that said record player was not intended for playing mood music in the highly explosive atmosphere of a glue-sniffing den. And such places are illegal anyway..... Safety standards are very good things for hiding behind. They effectively set a limit on how far you need go. Without them, and in a litigious society all equipment would become infinitely expensive to design out all risks and to insure against any you missed. Your modified radio may be to a thoroughly excellent level of safety, but it's not the radio that gets judged, it's the paperwork! David
1st Jan 2019, 11:53 pm | #14 |
Provided any modification is carefully considered and competently done, then I would be very surprised indeed if a court found the modification "illegal"
IMO, it is on a par with fitting smoke detectors to a home previously lacking same. It is a clear improvement, even without bringing to rest of the property up to the latest standards. Or fitting electric lights to a horse drawn vehicle. |
1st Jan 2019, 11:58 pm | #15 | ||
...and that hits the nail on the head!
There are lots of brilliant keyboard players and then there is Rick Wakeman..... Last edited by Sideband; 2nd Jan 2019 at 12:06 am. |
2nd Jan 2019, 12:17 am | #16 | |
Believe me they know how to charge for all this.....
2nd Jan 2019, 1:08 am | #17 |
I've quoted a paragraph from this document. I don't know if fitting an earth would count as a modification though?
Safety requirements for second-hand or hired electrical equipment You should be aware of your responsibilities under the Electrical Equipment (Safety) Regulations 1994 if you supply electrical equipment that is:
The safety of second-hand equipment that is supplied in the course of business - including auctions - is controlled by the regulations. However, it does not need to satisfy the CE marking requirement, and does not need the EC DoC or the technical documentation. Equipment is classed as second-hand if it has previously been supplied to an end user in the EEA. An end user means the consumer, and includes commercial and industrial consumers. While there is no mandatory requirement for second-hand equipment to undergo any safety testing, you must only supply equipment that is safe so as to avoid committing an offence under the regulations. The supply of electrical equipment that is in need of reconditioning or repair to someone who carries on a business of repairing and reconditioning electrical equipment is excluded from the regulations. The sale of articles as scrap is also excluded. Modified and refurbished electrical equipment Modified and refurbished equipment are included within the scope of the regulations. Where equipment is refurbished to its original specification, it will be treated as second-hand equipment. However, if the refurbishment uses different types of components, it will be considered as modified electrical equipment. Modified equipment will need to be assessed by the person carrying out the modifications to determine whether the modification may have introduced hazards or risks which were not covered by the original design. In this case, it is likely that the equipment would be considered as new equipment rather than second-hand equipment. This will require the person carrying out the modification to carry out all of those exercises required of an original manufacturer. For example, preparation of technical documentation, drawing up an EC DoC and placing the CE marking on the product. Regards David
http://www.youtube.com/ My Nixie Clocks Last edited by Radio_Dave; 2nd Jan 2019 at 1:18 am. |
2nd Jan 2019, 1:32 am | #18 |
This subject has been discussed a few times on here, the last time just a couple of months or so ago - I think it came up in the radio section.
Exactly as in post #16 above. A beginner and unqualified amateur isn't going to be (or should I say likely to be) competent enough to do the necessary modifications to an acceptable standard. I've seen first hand amateur attempts at adding isolating transformers and earths to record players, and it's cringe worthy, making the equipment more dangerous than it was before! I know a real life true story where someone got seven years in prison (I think he was out after about three) for doing "illegal" modifications to something. I believe he even documented it on the internet, with pictures. I did try to find it at the time, but I think 'administrators' quickly removed it after the 'accident' happened. I can't say too much, and it was quite a few years ago now, but death was caused and the chap lost everything and had to move out of the area after his release. I knew someone involved in the case, so know first hand what can happen if you don't have paper qualifications, don't do it right and try to make up your own rules regarding what you can and can't do. I generally leave things as original, but do sometimes fit a three core mains lead to replace a two core lead on transformer isolated equipment that's had the original lead cut off and I've got a good three core lead to hand. The big difference is that I 'do' have a paper qualification to wave at the judge, and would be prepared to back up what I'd done if the worst ever happened. The reality is that the risk of something happening if the job has been done properly is very remote indeed. It's even fairly unlikely that there would be a serious accident causing injury, damage or death if the job had even been bodged, as we've all seen the horrors that have been got away with in the past. The chap who went to prison was very unlucky - there was probably more chance of him winning the lottery jackpot than what happened to him, but regardless of that, it's always worth being aware of what could potentially happen if you're very unfortunate. |
2nd Jan 2019, 1:34 am | #19 |
“…if the refurbishment uses different types of components, it will be considered as modified electrical equipment.”
That sounds problematic – what would count as a diiferent type of component? Replacing a two-core mains lead with three-core? Replacing a faulty potentiometer mains switch with a toggle switch? Replacing a 100μF cap.with a 200μF? Adding an audio input socket to an old radio? Substituting a solid state rectifier for a valve rectifier, etc, etc? Could be a problem for some of the items in the “For sale” thread on this forum…. Unless they were clearly certificated or stated as "Scrap only"! Last edited by Boulevardier; 2nd Jan 2019 at 2:02 am. |
2nd Jan 2019, 2:28 am | #20 | |
I do my best based on a working lifetime of experience. I'm too old to worry. The regulations abounding in the modern world are too complicated for me to fully comply with even if I understood them all. I shall carry on to the best of my ability and for my continued enjoyment. |
