Old 15th Jan 2019, 11:10 pm   #21
Wendymott
Wendymott's Avatar
Default Re: Retro computer homebrew: Orton Karenbak-1 computer
Hi Karen... back to that "old" chestnut..to minimise solder fumes as you say as with pvc coating fumes.. I have a small Ex puter fan fixed to the bench blowing air across my face..sometimes I forget to switch it on.."age"
Should get out more.
Regards
Wendy G8BZY
Wendymott is offline
Old 16th Jan 2019, 12:40 am   #22
Karen O
Hi Wendy,
My use of Nylese goes back some thirty-five years.
I was an incorrigible youth back then
Now I've got a growing list of ailments to remind me that I'm not indestructible.
Karen O is offline
Old 18th Jan 2019, 10:20 am   #23
wireless_john
wireless_john's Avatar
OK, Ive got the wiring pen and spools and a suitable piece of single sided copper clad board. I might still get a Eurocard though - it'll save a lot of centre popping and drilling!
Then I'll have to sort through my boxes of IC's - that might take longer!
John
ID:	176618   Click image for larger version
GQRP Club 4704 - BVWS Member
wireless_john is offline
Old 18th Jan 2019, 3:17 pm   #24
Karen O
Blimey! Drilling copper clad board for twenty-five ICs sounds like hard work. I could never get the spacing even enough, resulting in my IC sockets refusing to seat
But don't listen to me. This is someone who wanted plain perf board so etched away the copper on some vero board!
Karen O is offline
Old 18th Jan 2019, 4:13 pm   #25
dominicbeesley
dominicbeesley's Avatar
If you don't mind the expense I can recommend these boards http://www.roadrunnerelectronics.com...Boards/Oktapad
The are very well made, have nice pads and stand up to heat well. I've tried cheaper ones but to get the enamel to melt you need the iron HOT and when prototyping I end up re-doing joints over and over ending in lifted pads. The reverse has a nice ground plane too.
I can also recommend their wiring pens (and kits) the wiring pen has a metal nozzle (rather than the plastic one on the vero which I, of course, quickly melted!)
The also do the combs but I didn't bother with them and went rat's nest as this was a "make it up as you go along" project...https://stardot.org.uk/forums/viewto...=15350#p210135
D
ID:	176639   Click image for larger version
dominicbeesley is offline
Old 18th Jan 2019, 4:28 pm   #26
wireless_john
Thanks for that! I've been through my TTL box and very few HC IC's. I've got plenty of LS though. They should be OK shouldn't they? Just a bit more power?
On the spreadsheet, the ones highlighted in red are the LS versions of the HC ones in the computer.
I don't mind the drilling so much as centre popping all the drilling positions through 0.1" squared paper! One dodgy hit and it all goes wrong - you can't re do it!
John
Old 18th Jan 2019, 4:35 pm   #27
wireless_john
I usually wrap the wire round the pin a few times, then snip it off with a pair of scissors. Then I solder it so the soldering iron never gets near the plastic tip.
John
Old 18th Jan 2019, 4:40 pm   #28
dominicbeesley
I must be more cack-handed I found it always jumped off unless I got it soldered quickly!
I'll be interested to see how you get on. Do keep posting pics.
I am playing with the idea of recreating one of these in an FPGA or CPLD but I suspect that will end up with all my other half started projects!
D
Old 18th Jan 2019, 4:57 pm   #29
wireless_john
Somebody called Lawrence Wilkinson did that - emulated an IBM 360 in an FPGA. I met him at Bletchley Park about 10 years ago.
http://www.ljw.me.uk/ibm360/vhdl/
Well over my head!!
John
Old 18th Jan 2019, 5:47 pm   #30
wireless_john
Karen, I've spent all afternoon on this looking at components etc and what I have in my junk boxes.
1. I have most of the ICs but not HC family, only LS types. They should work OK do you think, at the expense of a bit more power?
2. I don't have 74LS4040 IC 7 and 17, and they don't seem to exist. 74HC4040 seems readily available so is it OK to mix them with 74LS ?
I already have a nice project box in my "come in handy" pile. Looks like it finally has!
Regards
John
Old 18th Jan 2019, 5:51 pm   #31
TonyDuell
I'll second the recomendation for the Roadrunner wiring pen. It's very useful for one-off projects like this.
As for drilling holes for an IC socket in copperclad board, I used an odd bit of stripboard as a drilling jig.
At one time you could get a tool that consisted of a drill bit with a cylindrical cutter round it. It drilled the hole and then cut away the copper leaving a nice circular pad round the hole. No idea where you'd get one now.
TonyDuell is offline
Old 18th Jan 2019, 7:17 pm   #32
Karen O
Hi John,
You can mix LS TTL and HCMOS but you have to add pull-up resistors wherever an LS output drives a HCMOS input. Bear in mind that some HCMOS gates are Schmitt triggers and are used for generating delays.
Karen O is offline
Old 18th Jan 2019, 7:43 pm   #33
I remember the IC pin number labels for the back too, mirror image of course.
Old 18th Jan 2019, 10:32 pm   #34
wireless_john
Something you learn the hard way!!
John
Old 19th Jan 2019, 5:41 pm   #35
wireless_john
The MODE control appears to be a 5 pole 4 way rotary switch. Is there such a thing?
I found a 6P4W on Farnell and it was £69!!
I haven't been able to find one so far.
John
Old 20th Jan 2019, 10:55 am   #36
wireless_john
Well, that switch has turned in to a bit of a show stopper. Can't seem to get one anywhere without spending a lot of money, which I don't want to do.
I was hoping to build it with bits from my junk boxes, and I do have most of it. If nothing else, I've been through all my logic IC's now!
Back burner for now, till I see a suitable switch somewhere.
John
Old 20th Jan 2019, 12:15 pm   #37
Trevor
Rs and others used to make a stackable selector switch 1 long shaft and i seem to remember single pole 12 way wafers you just added as many wafers as poles required
have you looked at this
Trev
Trevor is offline
Old 20th Jan 2019, 1:48 pm   #38
TonyDuell
I remember those switches from RS. They were called 'Makaswitch' or some similar term and came in 2 sizes. The switch wafers had 12 fixed contacts and existed in single pole, 12 way, 2 pole 6 way, 3 pole 4 way and 4 pole 3 way I think. There were also screening plates, spacers, a mains-rated switch, etc.
But getting back to the problem. The switch here seems to select logic signals. I think it would not be too much work to replace it with a handful of TTL ICs (AND gates, effectively) and a single pole switch.
Old 21st Jan 2019, 9:08 am   #39
wireless_john
Hello Trevor, yes I had considered that and I remember the Makaswitch but they're more than I'm prepared to pay!
Tony, I think I'll be going along with your suggestion. I spent an hour looking at it yesterday and I think it could be done with three or four 74HC08 (Quad 2 input AND). I've got one, they're still quite cheap to buy and I have a 1P4W BBM rotary switch.
In the meantime, I'll keep my eyes open for a switch!
John
Old 21st Jan 2019, 6:57 pm   #40
What about two 3 pole 4 way swithces, you will have to turn them together, join them with levers and a link (only goes +/- 60 degrees should be OK) or put them front to front and wire one backwards. Big edge knob for turning.
