Old 17th Oct 2018, 6:42 pm   #1
Jon_G4MDC
Jon_G4MDC's Avatar
Default Pye Transport
There are those here that will recognise this title.
Neither Amateur nor Military but somewhere between the two.
It was a network that was very useful in it's day but I find very little on record.
Any contributions?
I won't add anything yet in case this is not the right place.
Jon_G4MDC is offline
Old 17th Oct 2018, 8:50 pm   #2
G6Tanuki
G6Tanuki's Avatar
Default Re: Pye Transport
I'm only familiar with the low/high-band frequencies which in the 70s and 80s Pye had licensed for use on their own operations and demonstrations. At least two of these were AM VHF-airband [Zebra One/Two and Zebra Ground are callsigns that come to mind]
G6Tanuki is offline
Old 17th Oct 2018, 8:56 pm   #3
CambridgeWorks
CambridgeWorks's Avatar
72.35Mhz mobile TX. 85.85Mhz base TX. Usually set to talkthrough out of office hours. My callsign was "Pye Notts Howe". 1977 to my deliberate "redundancy" in March 1990.
Commonly known as "Transport Scheme".
Rob
Apprehension creeping like a tube train up your spine - Cymbaline. Film More soundtrack - Pink Floyd
CambridgeWorks is offline
Old 17th Oct 2018, 9:16 pm   #4
Jon_G4MDC
Jon_G4MDC's Avatar
I didn't know about the airband stuff - very interesting.
Rob has explained a pile of crystals I still have for all sorts of sets.
I think I was Pye Project 56 - Systems Installation Dept from Cambridge.
It could turn out well or not so well when you turned up on far away schemes...
Old 17th Oct 2018, 10:26 pm   #5
G6Tanuki
G6Tanuki's Avatar
A list of legacy Pye related frequencies are listed here: http://irishradio.tripod.com/ni.htm
G6Tanuki is offline
Old 18th Oct 2018, 5:26 pm   #6
Jon_G4MDC
Jon_G4MDC's Avatar
Ah yes - lists like that probably meant trouble once upon a time but not any more I suppose.
It was the 72.35 MHz Mobile TX and 82.85 MHz Base TX that I was talking about here in the main.
There were the demonstration channels too but I think these could be used short term by any of the big companies. (I never knew the exact rules on them? - help!) I know I put a survey transmitter on demo frequencies at Hannington and went off measuring for the day but at some point the Tx went off.
When I came back to site (long drive - good site), to investigate, the TX crystal was left on top of the gear with a note - please don't do this.
I still wonder about that. Who was it?
Old 18th Oct 2018, 8:54 pm   #7
CambridgeWorks
Jon. Typo? It is 85.85Mhz.
Low band had splits (mobile TX/Rx) of 13.5Mhz 72/85 ish and 10Mhz 77/87 Mhz ish. Simplex 86Mhz ish.
Rob
Old 19th Oct 2018, 6:17 pm   #8
Jon_G4MDC
Jon_G4MDC's Avatar
haha Yes Typo!!
Old 19th Oct 2018, 11:13 pm   #9
Refugee
Refugee's Avatar
I have got an old GEC set kicking around that keyed up to something in the 80Mhz region.
Never been powered up for 30 years. I did take a photo of it when I was moving my workshop a few years ago.
Refugee is offline
Old 23rd Jan 2019, 3:56 pm   #10
TALKINGWITHPYE
Location: Carrickfergus, County Antrim, Northern Ireland, UK.
Yes 72.35 and 85.85 were also used here in Northern Ireland when I joined in 1970. I had a boot mount cambridge in my car and enevitably I forgot to switch off one night and next morning resulted in a dead battery, so I fitted a relay to switch off the tx valve heaters when the ignition was turned off. I still use Philips kit on 2 metres in my car, though somewhat more modern, like an fm1100.
Dave GI8LCJ
TALKINGWITHPYE is offline
