11th Jan 2015, 1:55 pm | #1 |
EHT fizz
I'm working on a Marconi 2955 VDU driver board. I have ring-tested the LOPT and I have replaced the BU806 driver transistor. I don't have much experience with EHT circuits so I'm looking for guidance. The problem is that when first switched on, after warming up for a few seconds I get a perfect display but after a few more seconds there are four detected symptoms: A fizzing sound starts up which gets louder, but I can't work out where it comes from The display starts to fade until it can't be seen even with the brightness on full The current drawn into the board starts to rise. The measured EHT voltage slowly falls to below 2kV I'm hoping there's a capacitor which is breaking down and really hoping it isn't the LOPT !
11th Jan 2015, 2:12 pm | #2 |
Re: EHT fizz
Have you tried it with the lights off? You might be able to see some visible discharge in the dark.
11th Jan 2015, 3:29 pm | #3 |
Re: EHT fizz
Hi Richard, the eht brushing is a symptom of corona discharge, carefully dust off using a clean dry paint brush, around the eht connection to the tube. Beware, because the tube acts as a capacitor and holds a charge! Dust off the eht lead and lopt, then as AJS says, turn the lights off and see if you can see any tracking to ground. It could be a capacitor failing, but it could just be overloading caused by the excessive eht drain.
Bill |
11th Jan 2015, 5:23 pm | #4 |
Re: EHT fizz
It's generally the EHT cap on the CRT.
The way I used to clean it and the CRT was to wipe both items with a rag soaked in meths. In damp houses I wiped the CRT with WD40. Sometimes the plastic cap was beyond repair because of continual tracking.
Mike. |
11th Jan 2015, 5:50 pm | #5 |
Re: EHT fizz
Wow! WD40 actually being used for Water Displacement.
11th Jan 2015, 6:21 pm | #6 | |
Re: EHT fizz
Cheers, GJ
http://www.ampregen.com |
12th Jan 2015, 7:00 pm | #7 |
Re: EHT fizz
Thanks! I sorted the fizz easily - the EHT cap was held off the tube by part of the tube support strap, once I'd moved that the noise went away.
I have another problem with the board now for which I'll start a new thread.
