Old 16th Oct 2018, 8:57 pm   #1
SiriusHardware
Default M1 * 12mm screws / bolts?
Might anyone have a pair of m1 diameter by 12mm long screws, ideally with low profile heads, and matching m1 nuts?
Required for the reassembly of a sealed PCB-mounting potentiometer which was originally held together by (2 of) 1mm * 12mm aluminium rivets (the rivet heads had to be drilled off to get it apart).
SiriusHardware is online now   Reply With Quote
Old 16th Oct 2018, 10:43 pm   #2
Default Re: M1 * 12mm screws / bolts?
Try here?
https://www.accu.co.uk/en/cheese-hea...2-SFE-M1-12-A2
Google is your friend (in this case at least).
Herald1360 is online now   Reply With Quote
Old 16th Oct 2018, 10:55 pm   #3
SiriusHardware
Herald, thanks, although I have no idea how you found those because the search engine on that site itself is hopeless - I tried to find Pan head versions by searching further for "M1 X 12mm" on the site and it could not even find the cheese head one you linked to.
A good start, anyway, thanks.
Old 17th Oct 2018, 12:01 pm   #4
I just googled M1*12 screw and it came up about 6 hits down the list.
Looks like their pan head range doesn't go that small:
https://www.accu.co.uk/en/161-pan-head-screws
M1 studding is also available:
https://www.ebay.co.uk/itm/M1-0-M1-2...-/131353754670
Old 17th Oct 2018, 12:49 pm   #5
valveaudio
You could also try 14BA they may be easier to find at model shops etc.
Trevor
valveaudio is offline   Reply With Quote
Old 17th Oct 2018, 5:37 pm   #6
emeritus
I seem to remember that long 14BA screws were used for connecting points to point motors located under the baseboard, so model railways suppliers would be a good place to try.
emeritus is offline   Reply With Quote
Old 17th Oct 2018, 6:58 pm   #7
SiriusHardware
I'm afraid traditional model shops are becoming an endangered species these days - I was thinking maybe I should try a horologist / clock and watch specialist, but they are also rather rare now. I doubt whether many watch repair centres can do much more than change a battery or a strap nowadays, let alone supply precision miniature nuts and bolts in a range of sizes.
Herald, I'll probably go for the first ones you pointed out - I can always file the heads to a lower profile. Thanks again for looking.
Old 18th Oct 2018, 9:48 am   #8
valveaudio
Have a look here for 14 BA. http://www.hobbyholidays.co.uk/products.php?cat=113
Trevor
Old 21st Oct 2018, 5:27 pm   #9
BAIRD 700
Try wilko, they seem to have every nut and bolt made-you buy them by the bag full either 2.00/3.00
Leslie Hine.
CUMBRIA.
BAIRD 700 is offline   Reply With Quote
Old 21st Oct 2018, 9:17 pm   #10
SiriusHardware
Thanks all, although, BAIRD 700, I'm not sure you realise how small M1 bolts are - I've never seen general hardware shops selling such small bolts or screws. Chains you might expect to keep such things, like Hobbycraft, don't sell them either.
Old 22nd Oct 2018, 9:09 am   #11
M0FYA Andy
Try EKP Supplies, I've found them to very helpful in the past -
https://www.ekpsupplies.com/index.php
Andy
M0FYA Andy is offline   Reply With Quote
