Old 11th Aug 2004, 6:40 pm   #1
Radio_Dave
Radio_Dave's Avatar
Default Isolating transformer questions
I keep wondering whether to buy an isolating transformer for safety reasons. However I dont really understand how this item provides protection. I assume it's only needed for ac/dc sets?
Everybody always says use an isolating transformer but nobody ever says why! Can somebody please explain
Radio_Dave is offline
Old 11th Aug 2004, 7:10 pm   #2
paulsherwin
paulsherwin's Avatar
Default Re: Isolating transformer questions
An isolating transformer allows you to earth the chassis of the set being worked on, even if it's a transformerless set. This is inherently safer (no chance of a live chassis by mistake) and allows the use of earthed test gear like signal generators and scopes.
Opinions differ as to how important an isolating transformer is. It all depends on the environment you work in and whether you use test gear a lot. Needless to say, if you *don't* use a transformer you need to be very, very careful about mains polarity.
HTH, Paul
paulsherwin is online now
Old 11th Aug 2004, 7:21 pm   #3
Radio_Dave
Radio_Dave's Avatar
HiPaul,
Earthing the chasis makes sense but what, if any, protection would I have from electrocution?
Thanks
Old 11th Aug 2004, 7:25 pm   #4
ppppenguin
ppppenguin's Avatar
If you have a AC/DC set, then the chassis is connected to one side of the mains. If it's the live side then the whole chassis is live. I'm sure that most forum members have been caught somewhere and lived to tell the story. My initiation was on a Bush TV80 " portable " TV when I was about 15 years old. I knew to test the mains polarity with a neon screwdriver but somebody had bridged out the neutral side of the mains switch. I turned off the set and touched the chsssis. Only once.
Actually I think all kids ought to get an electric shock at some point fairly early on just to prove to them that electricity is dangerous if you do the wrong thing. The only problem is that we might kill a few by mistake. It's called un-natural selection!
ppppenguin is offline
Old 11th Aug 2004, 7:48 pm   #5
paulsherwin
The main safety benefit is to ensure that the chassis is never live. This is particularly important when working in a proper workshop environment where you'll be surrounded by earthed equipment and metal fittings. In a typical 'dining table' workshop, most of the stuff around you will be insulating or floating so the live chassis is unlikely to give you a serious shock. (Most of us will have touched a 240V live connection at some time, and it's pretty unpleasant, but it's not dangerous if you're not earthed anywhere).
Even with an isolating transformer, if you grab hold of mains live with one hand and the chassis with the other, there's a good chance you'll die. An old repairman's trick was to work with one hand in your pocket.
Best regards, Paul
Last edited by Paul Stenning; 26th Dec 2004 at 8:45 pm. Reason: Fix link or code for vBulletin
Old 11th Aug 2004, 7:55 pm   #6
Radio_Dave
Radio_Dave's Avatar
Thanks Paul you've answered all I needed to know
Old 11th Aug 2004, 8:02 pm   #7
Chris_C
Chris_C's Avatar
Hi All
I would amend this to one hand behind your back. A friend of mine was working on an amateur transmitter with one hand in his (trouser) pocket. He clipped the o/p valve anode top cap (approx 600 v), the reflex caused him to jerk backwards against a door frame. As he couldn't get his arm free in time, he hit it with a lot of force, the outcome was he broke the arm .
Yes high voltages can be dangerous in more ways than one.
Chris C G8TJR
Last edited by Paul Stenning; 26th Dec 2004 at 8:49 pm. Reason: Fix link or code for vBulletin
Chris_C is offline
Old 11th Aug 2004, 9:20 pm   #8
Sideband
Sideband's Avatar
The main advantage of an isolating transformer is as Paul said, the ability to used earthed test equipment. Also you don't need to worry about what way round the chassis is connected on AC/DC sets (or those run from autotransformers or 'heater transformers' like some 'midget'sets are).
In isolation transformer will NOT prevent electrocution but reduces the risks.
Rich.
Last edited by Darren-UK; 26th May 2007 at 12:25 pm. Reason: Deleted ref to an early thread which no longer appears to exist.
Sideband is offline
Old 12th Aug 2004, 9:36 am   #9
GMB
GMB's Avatar
I would say that the only advantages of an isolating transformer are for use with earthed test equipment, that it might limit the maximum short current in the event of a problem and that it isolates you from mains neutral - which can become momentarily dangerous when some (other) appliance decides to blow a fuse. If you joined earthed test equipment to mains neutral you might find a lot of current flowing between them and a house RCD would probably trip.
There are disadvantages.
It may lull you into a false sense of security and it prevents any RCDs that might be on the mains side from helping you.
The point is that if you allow one side of the isolated output to be joined to mains earth then the live terminal has EXACTLY the same lethality as the original mains did.
GMB is online now
Old 1st Sep 2004, 11:19 am   #10
Andrew_-_XVK6ZEA
Hi All,
Being new to your forum, I don't know if it is appropriate to ask a question here, or whether I supposed to start a new thread, but I MUST CLARIFY the following:
I thought I understood the correct use of isolating transformers until I read this here:
Does this mean that there would be circuit where the current flow caused by a short could not be sensed by the RCD and the person could be electricuted?
Andrew
Last edited by Paul Stenning; 26th Dec 2004 at 8:47 pm. Reason: Fix link or code for vBulletin
Old 1st Sep 2004, 12:08 pm   #11
ppppenguin
ppppenguin's Avatar
RCDs do not detect short circuits or overloads. They sense the difference betweenthe currents flowing in the live and neutral wires. Any difference is assumed to be a fault, possibly current flowing through your body.
Any fault on the output side of an isolating transformer cannot unbalance the live and neutral currents at the primary so an RCD in the primary circuit cannot give any protection.
An RCD in the secondary circuit can give no protection unless one side of the secondary is earthed before the RCD. THis is a rather odd way to use an isolating transformer and rather defeats the purpose.
The HT on an AC set with a mains transformer is always potentially dangerous. An RCD will not save you as the HT is on the secondary of an isolating transformer. In this case the transformer is in the set, not external, but the idea is the same.
THe main purpose of an isolating transformer is to ensure that the chassis on an AC/DC set is not at mains live.
There is no substitute for being aware of the risks and taking due care.
