Old 30th May 2019, 10:05 pm   #1
'LIVEWIRE?'
'LIVEWIRE?''s Avatar
Exclamation Repainting scale back plate of a DAC90A
I've recently begun work on a DAC90A, and, among other things, I need to repaint the metal scale backing plate. The original paint is flaking off and my question is 'What would be the best way to remove all the paint? With tat completely removed, I could then either spray or brush paint a new coat of similar white paint. The rear of the plate is also partially tarnished, but I may either leave that as it is, as I'm not sure how best to proceed with that other than to possibly respray it it metallic silver or something similar. B.t.w, I don't have access to ultrasonic cleaners or anything of that sort.
'LIVEWIRE?' is offline
Old 30th May 2019, 11:26 pm   #2
Paul JD
Default Re: Repainting scale back plate of a DAC90A
With a small part like that abrasive paper and a bit of elbow grease would probably do the job as well as anything, start with a coarse grade to cut through the old paint and then use finer grades to get a nice flat surface to paint. Failing that you could use paint stripper (although with modern health and safety regs a lot of consumer grade paint strippers are not very effective - not like the old Nitromors that worked in seconds!) or depending on what type of paint it is cellulose thinners or acetone might remove it.
Paul JD is offline
Old 31st May 2019, 9:32 am   #3
Silicon
If the scale back plate is made of aluminium you need to use a paint stripper that does not contain Caustic Soda. It will corrode the aluminium.
Silicon is offline
Old 31st May 2019, 10:36 am   #4
'LIVEWIRE?'
The back plate is steel, Silicon, so no worries there, but I've removed some of the flaking white pain with what is described on the pack as 'Grade 5 Cabinet (sand)paper, used dry, so, either with a coarser grade or by damping the surface, I should be able to remove all the white paint by that method.
