30th Oct 2014, 4:50 pm | #21 |
Re: Philips G17T320-02 B&W TV schematic/help please.
cheers guys,would be good to confirm 100%,how they are supposed to measure.
the colleague i mentioned send me 2x BF196 & 2X BF197. could it be poss that all 4 of them are faulty and measuring one way on the collector/emitter junction ? |
30th Oct 2014, 5:19 pm | #22 |
just bought BF198 & BF199 from ebay.
direct equivalents,400mhz & 550mhz respectively. same as originals |
30th Oct 2014, 6:06 pm | #23 |
I got my new old stock ones from Cricklewood Electronics...and they were ok!
All the very best, Tas |
30th Oct 2014, 6:19 pm | #24 |
Forgive my lack of gen on this one zen, but wasn't the original symptom one of visibly low eht and excessive ht on the smoothers. Where are the aforementioned bf transistors in the circuit? Yourre very revered on your normal site, I cant see an old mono set holding you back much longer, members on this site no offence intended, I like the oldies, equipment of coarse! Something in the back of my mind hints that on a digital meter you could get slight readings on the pins you wouldnt usually, as you could with germanium ones, and they would still be OK.
30th Oct 2014, 6:34 pm | #25 |
BF transistors are in the 2 IF cans
poss Tony regarding DVM,i will find out when the Ebay ones arrive.yes your correct on the original symptoms,but it seems tv is experiencing one issue after another. CRT theory has been forced out of my head to make room for modern sets i have a headache |
20th Nov 2014, 3:46 pm | #26 |
transistor in I.F can ok.slightly led me astray
as i have been finding quite a few high value resistor,decided to blanket cold check all first on the list is REF 104 ( 390K ),on tube base. reads high at 570K |
20th Nov 2014, 4:26 pm | #27 |
2 resistors in series,unkown ref.
390K,reads high at 495K 820K,reads high at 1M1 |
20th Nov 2014, 6:25 pm | #28 |
discovered diode REF 469 ( BYX10 ) to be O/C
replaced,using a BY228,powered on and |
21st Nov 2014, 11:10 am | #29 |
Ahhhh lovely
Has this set got the original rotary six position channel selector or has it been replaced with a six slopey button Philips 550 version?
21st Nov 2014, 2:36 pm | #30 |
Hi
Tas - I remember those! Just the same as the 550 series to repair - open the clips, Brasso the board and stretch the contacts, then reassemble, only to discover you've put the contacts back upside down so it works backwards... Always brilliant tubes as said above. A nice looking set if not too reliable - as the great LLJ said - pretty little things are often naughty! Glyn |
21st Nov 2014, 3:44 pm | #31 |
yes Tas,has original channel selector.
just one more part required to complete require the main smoother,it's a 2 X 400MF,which needs to be a specific size to fit into clamp. DIMENSIONS DIAMETER = 38MM HEIGHT = 78MM 2 X 560MF caps in there at the moment,joined with duck tape,which is not really ideal. |
