Old 4th Dec 2008, 10:07 am   #1
kennyhew
Default Leak Delta 30. Speaker Connections.
I recently acquire a Delta 30 but am been unable to locate information on the DIN pin configuration for speaker output.
Is anyone able to shed light on this?
Thank you in-advance!
kennyhew is offline
Old 4th Dec 2008, 6:13 pm   #2
geofy
Post Re: Leak Delta 30. Speaker Connections.
Welcome Kenny.
The diagram shows the output stage of the Leak30, the speaker output if a DIN socket should not be to difficult to wire up, the plug will have a round pin and a flat pin, one plug to each speaker with the phase correct. If the twin flex has a white marker on one side make sure this goes to the same pin in each plug.
Geof
geofy is offline
Old 4th Dec 2008, 7:50 pm   #3
audiomm
Default Re: Leak Delta 30. Speaker Connections.
Originally Posted by kennyhew View Post
The DIN speaker plug configuration is: Small round pin is +ve. Flat pin is -ve.
regards
Mike
audiomm is offline
Old 5th Dec 2008, 1:40 am   #4
HP3400A
The two-pin DIN plug has its flat pin connected to the amplifier chassis. The round pin is fed from the output stage and is the 'live' one. One plug is for the left speaker, one for the right speaker - should be marked which is which on the rear of the amplifier.
Martin
HP3400A is offline
