25th Nov 2008, 9:09 pm | #21 | |
Re: Replacing caps in dansette RG30
This is hardly surprising. On the noise problem, please see a very recent thread on this by searching CFT's - there's a lot of encouraging advice and home-brew research in there!
Al |
25th Nov 2008, 10:51 pm | #22 |
My Grundig transistor radio from the early 70s, which I recently repaired, works fantastically on LW at 198KHz. So I guess there's probably something wrong. I moved the coil along the rod but it makes little if no difference. Any suggestions about how to start checking for things which may cause this?
25th Nov 2008, 11:12 pm | #23 |
I'm sorry to say that this is where my radio knowlede ends
Have you checked that the waveband switch is clean? Band switching doesn't seem complicated; seems to involve selecting L5 or L6 on the ferrite rod, and bringing C6 into play. Has anyone else got one of these to let us know what LW performance is like? Good luck, Nick. |
26th Nov 2008, 10:53 am | #24 |
Nick
I took your advice and took a look at the band switch. One of the screening wires I had resoldered (badly) had come away. I re-soldered it and hopefully did a better job this time and LW sounds much better now. I am going to put that earth wire in which reduces the background hiss even more. So I think everything will be OK now. Thanks vasco |
26th Nov 2008, 8:09 pm | #25 |
Astral Highway
Thanks for the info about CFTs. If my room light is on (energy-saving) and I move my hand near to the chassis the noise increases enormously, but this does not happen when the light is switched off. |
26th Nov 2008, 10:13 pm | #26 | |
With some of these banded capacitors, the first colour band or blob is sometimes thicker. Rich.
1st Dec 2008, 6:43 pm | #27 |
I thought of that but they both have a silver-grey blob as well and if you read them both with the silver blob to the right then they come out as I said before and don't agree with the schematic. Surely you can't read one of them in one direction and the other in another?
