Old 8th Sep 2019, 5:22 pm   #1
Edwin!101
Default Ekco U245 Cleaning and testing Tips
Hi everyone!
As the title suggests I have recently got an EKCO U245 which has been sat gathering dust for at least 20 years and so it is incredibly dirty (pictures attached below). I have cleaned the outside of the case and I have removed the chassis and cleaned the inside of the case too however I have not begun cleaning the chassis yet.
Because the radio is so dirty I do not dare to switch it on yet just in case it damages any of the components via a short etc. I was wondering if you guys had any tips or hints on:
a) what would be the best way to clean the chassis and the components to ensure there are no shorts or problems before probing it but also without damaging the components?
b) Once it is looking nice where should I start with testing it? (or should i just turn it on once cleaned and hope for the best?) I have a multi meter and a soldering iron and can get capacitors if they need replacing.
Thanks in advance for any help!
ID:	189699   Click image for larger version
ID:	189700   Click image for larger version
Edwin!101 is offline
Old 8th Sep 2019, 6:21 pm   #2
Nuvistor
Nuvistor's Avatar
Default Re: Ekco U245 Cleaning and testing Tips
Have a read of this before starting.
https://www.vintage-radio.com/repair...ion/index.html
A hoover and soft paintbrush will remove most of the dirt.
Don’t switch it on until you have done some basic safety checks and changed some components that are known to fail.
This is a live chassis set, one side of the mains is connected to the chassis, confirm it’s the neutral side or better still use an isolation transformer. You will need to take care when working on any radio, electric shocks can kill.
Sorry if this seems alarmist but I don’t know your skill.
Frank
Nuvistor is offline
Old 8th Sep 2019, 6:40 pm   #3
HamishBoxer
HamishBoxer's Avatar
Those wax caps will most likely all be duff.Only change one at a time with careful check of correct value/voltage replacement.Excluding the wax flat mica one,s which are normally fine.
If in doubt just ask!
HamishBoxer is offline
Old 8th Sep 2019, 8:25 pm   #4
Edwin!101
Thankyou for the responses I wasn't expecting anyone to get back to me so fast!
I will try and remove all the dust and dirt this week and will post again if there are any problems. I will have a look at replacing the capacitors once I've cleaned it as I'm not sure I'll be able to read the values under all that dust!
I am just wondering if I should be careful about electrostatic discharge(ESD) when using a toothbrush? Is ESD still a big problem with older components such as these?
Thanks again!
Old 8th Sep 2019, 9:51 pm   #5
Simon Gittins
ESD is the one thing you don't have to worry about as valves are far too old to be affected!
Careful with dusting though, you really want minimal disturbance before carrying out the initial checks as advised above.
Simon Gittins is offline
Old 8th Sep 2019, 10:22 pm   #6
Nuvistor
Nuvistor's Avatar
Service manual.
https://www.service-data.com/product...12/2195/m11512
Frank
Nuvistor is offline
Old 8th Sep 2019, 11:12 pm   #7
Sideband
Sideband's Avatar
ESD is only associated with transistor junctions. Valves don't care about ESD and neither do any of the components. All you need to do with this set is replace the paper capacitors as stated above. Leave the mica caps alone....these will (usually) be OK.
Sideband is offline
Old 9th Sep 2019, 9:52 am   #8
ajgriff
ajgriff's Avatar
As part of your initial testing (long before applying power) check the continuity of the mains dropper resistor using your meter. It's the tall grey and scorched looking component in the bottom right hand corner of the first photograph.
Alan
ajgriff is offline
Old 9th Sep 2019, 10:01 am   #9
paulsherwin
paulsherwin's Avatar
These sets are tough as old boots and quite a good beginner's choice, though make sure you fully understand the live chassis issues before applying power. They're not difficult to work on.
That is certainly a grubby radio! There are various levels of chassis cleaning that you can do, everything from a quick paintbrush and vacuum cleaner job to a complete component level stripdown. It's unlikely to affect operation. I use the vacuum then clean the accessible parts of the chassis with a rag and some WD40, but I'm not bothered about getting it back to ex factory condition. I leave the underside of the chassis alone unless it's unusually filthy.
Don't clean the valves aggressively as all the print will come off. Dirt doesn't affect their operation.
There is a wire clip holding each valve in place. These go stiff with age, and just pulling the valves out can damage the glass locating pip on the side, so you will need to ease off or remove the clip using a screwdriver. The clip isn't really needed.
paulsherwin is offline
