Old 2nd Sep 2019, 12:22 pm   #81
Station X
Station X's Avatar
Default Re: Shaftesbury 519 amplifier
I'm losing the plot here. Have the smoothers now been reformed using a diode resistor combo?
Graham. Forum Moderator
Station X is online now
Old 2nd Sep 2019, 1:09 pm   #82
Guitarist28
Guitarist28's Avatar
Graham.
I was checking that the transformer was good to go first. Now I will endeavour to reform the caps.
Best regards
Guitarist28 is offline
Old 2nd Sep 2019, 1:43 pm   #83
Refugee
Refugee's Avatar
The heaters will most likely drop to about 6.5 volts with the valves in so it should be OK.
It looks like time to reform the caps now.
Refugee is offline
Old 2nd Sep 2019, 1:46 pm   #84
Guitarist28
I have just connected across pins 7 to 3 and switched on.... Immediate buzzing sound. That can't be correct??
Old 2nd Sep 2019, 1:47 pm   #85
Refugee
Refugee's Avatar
I hope that was not with a solid wire.
It should be with the resistor and diode.
Refugee is offline
Old 2nd Sep 2019, 1:59 pm   #86
Guitarist28
With 200kR 2watt and 1n4007 in series?
Old 2nd Sep 2019, 2:05 pm   #87
Refugee
Refugee's Avatar
That is right.
Refugee is offline
Old 2nd Sep 2019, 2:07 pm   #88
Guitarist28
Should it buzz though?? Am I better off starting with a lower voltage through a variac?
Old 2nd Sep 2019, 2:09 pm   #89
Refugee
Refugee's Avatar
It will buzz with a short circuit across the rectifier diode and it is also likely to damage the transformer.
Refugee is offline
Old 2nd Sep 2019, 2:10 pm   #90
Guitarist28
What I am doing incorrectly?
Old 2nd Sep 2019, 2:16 pm   #91
Refugee
Refugee's Avatar
You connected a solid wire where the diode and resister should have been.
Refugee is offline
Old 2nd Sep 2019, 2:20 pm   #92
Guitarist28
You misunderstand, I did use a diode and resistor in series between pins 7 & 3. I'm now at a complete loss what has happened.
Old 2nd Sep 2019, 2:54 pm   #93
Guitarist28
Oh dear, its now buzzing without any connections across the rectifier at all.
Old 2nd Sep 2019, 2:58 pm   #94
snowman_al
snowman_al's Avatar
Have you got the rectifier the right way round?
The 'cathode' (the band end) Must point to the pin 3. (It does not matter if the diode or resistor goes to pin 1/7 as long as the band points to pin 3.)
Never Leave Well Enough Alone...
snowman_al is offline
Old 2nd Sep 2019, 3:02 pm   #95
Guitarist28
It wasnt buzzing before I connected the diode/ resistor. So it appears something has now shorted out...... Where to start!
Old 2nd Sep 2019, 3:12 pm   #96
ms660
ms660's Avatar
You had the transformer shrouds off, were the bolts tightened properly when you re-assembled it?
Lawrence.
ms660 is offline
Old 2nd Sep 2019, 3:14 pm   #97
Guitarist28
I think I will have to take it apart again to make sure nothing is shorting out inside... What a pain!
Interesting point thought, it not tripping out my laboratory super fast rcd though??
Old 2nd Sep 2019, 3:44 pm   #98
Station X
Station X's Avatar
One matter never resolved is the resistance of the primary winding. What does it measure?
Old 2nd Sep 2019, 4:40 pm   #99
Guitarist28
Across the 2 purple primary cables.... 78R
Old 2nd Sep 2019, 5:01 pm   #100
Guitarist28
What an idiot..... Shrouds were loose, I'd not tighted them fully. It's not buzzing now so shall I try the resistor/diode again?
