Old 14th Jan 2020, 10:52 pm   #1
Tinker1966
Default Valve testing a 4212
I have recently acquired a very large valve - a 4212H, I believe.
Is it possible to test one of these huge valves ?
It is undoubtedly beyond me !
I have ascertained the filament has continuity and thats me done!
Is this a service that is provided by anyone ?
Many thanks
Tinker1966 is offline   Reply With Quote
Old 14th Jan 2020, 11:59 pm   #2
AC/HL
AC/HL's Avatar
Default Re: Valve testing a 4212
One of these: https://vintage-radio.net/forum/showthread.php?t=40716
Bill, BVWS member
Old 15th Jan 2020, 8:52 am   #3
Ed_Dinning
Hi Tinker, you should be able to run the filament supply up and then connect a voltmeter between cathode and grid. If the valve has emission you should get a small voltage reading.
Then you can think about other power supplies to try it in anger.
Ed
Old 15th Jan 2020, 9:04 am   #4
Tinker1966
Yes - thats the one.
Well - I have a voltmeter so thats a step in the right direction - but as to connecting up the filament I would have no idea what kind of voltage to apply and would be terrified of doing the wrong thing - I am led to believe this valve has a fair value, so it might well end upon ebay...
Old 15th Jan 2020, 4:05 pm   #5
Tinker1966
Ed
So - reading the link above it seems the filament runs at about 14v ?
If I apply that to the filament with a variac and connect a voltmeter to the other two pins I should get a reading .....
Am I on the right track ? I shan't do anything just yet .......!!
Thanks for the help
Old 15th Jan 2020, 5:10 pm   #6
David Simpson
There was a similar thread to this a few weeks before Christmas. See "Search". Also, I actually tested one a couple or so years ago, using a bespoke DC Rig, plus produced a Ia/Vg Graph which I could compare with an actual STC graph. Sourcing a high current heater voltage is the awkward bit.
Regards, David
David Simpson is offline   Reply With Quote
Old 15th Jan 2020, 8:23 pm   #7
rambo1152
rambo1152's Avatar
Regards, David
14V @ 6A would be the easy part for me.
Graham.
G3ZVT
Old 15th Jan 2020, 9:10 pm   #8
Car battery? With ln line fuses of course! Not quite 14V, but should suffice for testing.
CB radio PSU?
Keep the soldering iron hot.
Old 15th Jan 2020, 9:39 pm   #9
Tinker1966
Wow thanks Station X -
Car battery - I have several of those hanging about.
So connect that to the filament terminals and measure the other 2 with the voltmeter to see if there's any voltage .....
That's tomorrows project sorted
Old 15th Jan 2020, 10:14 pm   #10
Don't forget the fuses or you could find yourself doing some involuntary arc welding.
An alternative would be to connect to a car's cigarette lighter/accessory socket which will be fused within the vehicle.
Old 15th Jan 2020, 10:57 pm   #11
Tinker1966
Ok - fuses at the ready !
I will report back tomorrow
Old 16th Jan 2020, 10:25 am   #12
rontech
The National Valve Museum website for 4212 gives a PDF data sheet link
Time flies like an arrow, fruit flies like a banana
rontech is offline   Reply With Quote
Old 16th Jan 2020, 12:08 pm   #13
David Simpson
Aye Tinker, you'll be needing hefty Va & Vg supplies plus being able to measure in the region of 160mA Ia. Way beyond the VCM's & Valve Testers we all know. Plus you'll need to make a bespoke valve holder with sturdy valve pin connections. Don't be tempted to use cheapo crock-clip leads.
Jesus, was it all that long ago - 7th Oct.2015 was my "Testing the STC 4212D Triode" Thread.
My 4212D drew 6.3A at 14V Vh. And with 500V Va drew 160mA at -5Vg, but I started out gently at -50Vg. If you look at the STC family of Gm curves, you'll see that these fearsome valves were happy working in the 1KV Va region. Running Vh at 12V off a battery might do just to see the thing glow, but 14V would be needed to get comparisons with STC's data.
Caution - if your valve is a decent NOS one, it could be worth a few hundred quid, so don't phook it.
Regards, David
Old 16th Jan 2020, 12:25 pm   #14
If this were mine and I wanted to sell it, all I'd do would be to test the heater for continuity and state that it had continuity in my eBay listing or W.H.Y.
That's what I did with a load of 4CX250B's a few years back.
Old 16th Jan 2020, 12:56 pm   #15
Tinker1966
Thanks everyone for the advice - I have already tested for continuity of the filament and it is good.
I think on balance I shall leave it there and sell it as is.
Old 16th Jan 2020, 1:03 pm   #16
rambo1152
rambo1152's Avatar
Not quite, there won't be any voltage, you have to apply some and measure the current.
I'm just wondering how low a voltage you could use, and see some current and diode effect on a multimeter? Would a 9V battery be too low? Would -9v from a second battery be expected to cut the valve off or at least reduce the current?
More a classroom demo than meaningful testing, but it would prove there was some vacuum and emission.
(posts crossed)
Graham.
G3ZVT
Old 16th Jan 2020, 1:30 pm   #17
The OP was referring to the advice in post #3. ie measure the cathode to grid voltage.
Old 16th Jan 2020, 5:39 pm   #18
rambo1152
rambo1152's Avatar
That's interesting, I don't suppose you could detect the space charge with an AVO 8 though...
Graham.
G3ZVT
