Go Back   UK Vintage Radio Repair and Restoration Discussion Forum > Offered and Wanted Messages > Sets, Parts and Service Information Offered (private sellers only, exact price required, no swaps)
Sets, Parts and Service Information Offered (private sellers only, exact price required, no swaps) You may announce components or sets for sale or offered free here. Private collectors only - no traders. You must include an exact price. No swaps.
Old 22nd Oct 2017, 6:17 pm   #21
captainpugwash
Default Re: Meters FOC
Good afternoon again Mike.
That is certainly some meterfest.
Could I ask for a couple more please....post 17...picture 3...2 x square 4 hole meters directly above the thermo ammeter.
Thanks again,
captainpugwash is offline
Old 22nd Oct 2017, 6:33 pm   #22
Cobaltblue
Cobaltblue's Avatar
Hi Colin
I assume this is the two Elliot meters?
The micro-ammeter seems to work but the one scale in milliamps not.
Might be worth seeing if the problem is minor or not
Anyway currently both put aside for you.
Mike T
Don't care if it was a bargain why's it in my kitchen
Mike T BVWS member.
www.cossor.co.uk
Cobaltblue is offline
Old 22nd Oct 2017, 6:35 pm   #23
turretslug
Thanks Mike
Originally Posted by Radio Wrangler View Post
ID'ing them all is some fun!
Yes, would make a good end-of-year quiz, and there's probably enough eclectic knowledge on the forum for a tidy full house! I thought the Ernest Turner 200uA job might have been an ex-RA17 candidate too, ISTR they did something quite simple like monitoring envelope detector current, rather than the frequent co-opting of an AGC'd IF valve as a sort of VVM,
Colin
turretslug is offline
Old 22nd Oct 2017, 6:58 pm   #24
Radio Wrangler
Radio Wrangler's Avatar
Hi Mike, I don't want the meters. I just thought that identifying them might help them get to the right home.
Hi Colin, Yes the RA17 has metering switched between the IF detector current or the audio output voltage. Neither has the dynamic range of an S-meter. The switch is a toggle. The better the AGC does, the less variation you see on the meter!
The RA117 has a rotary switch and a third position giving a normal S-meter function by metering the current in an AGC controlled stage as is routine.
I think 200uA is the right sensitivity and that bezel shape is part of the RA17 product design and matches the little speaker.
Radio Wrangler is online now
Old 22nd Oct 2017, 7:00 pm   #25
Cobaltblue
Cobaltblue's Avatar
Apologies that was supposed to read Colin and now I have edited it does.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Old 22nd Oct 2017, 7:12 pm   #26
captainpugwash
Sorry Mike,was the reply in post 22 answering me or Colin ?
If Colin,how about the Elliot in picture 1 post 17 bottom left ?
Regards,
Old 22nd Oct 2017, 7:35 pm   #27
Cobaltblue
Cobaltblue's Avatar
Sorry David It got confused when RR though I was responding to him
It was of course you who asked for the two Elliots.
I was busy and didn't re read it all.
Mike T
Mike T BVWS member.
www.cossor.co.uk
Old 22nd Oct 2017, 9:39 pm   #28
James Duncan
Originally Posted by Cobaltblue View Post
This is more of the stuff kindly donated by John in Sidmouth.
Hi Mike
I need four meters for a club project ( power triode test rig)
0-10 volts meter, a meter to read 5 amps, a 300 milliamp meter and a meter to read up to 50 volts, anything near that would be great, if you have any left.
thanks MM0HDW
James Duncan is offline
Old 22nd Oct 2017, 10:40 pm   #29
Gridiron
Hi Mike,
I would like the meter marked NC, the German Netzspannung ?
one and the grey one if still available, if you could bring to RWB, I am also after an Ernest Turner meter 3" square 250uA for a GPO interference monitoring radio (pictures of some scales unclear).
Thanks, Mike.
Gridiron is offline
Old 23rd Oct 2017, 12:07 pm   #30
Diabolical Artificer
Diabolical Artificer's Avatar
Hi Mike, don't suppose you have a meter like this one here - http://www.vintage-radio.net/forum/s...d.php?t=140585 ? Bit tricky to see from your pics. Meter dia 2 1/2" 50uA to 100uA.
Am happy to take what's left after other folk's specific want's to save you going through them all.
Andy.
Old 23rd Oct 2017, 12:11 pm   #31
Cobaltblue
Cobaltblue's Avatar
Hi Andy
I will have a look this evening
Mike T
Mike T BVWS member.
www.cossor.co.uk
Old 23rd Oct 2017, 4:12 pm   #32
Pete_kaye
Pete_kaye's Avatar
I am after a working micro ammeter for use with crystal sets. Any left?
Pete_kaye is offline
Old 24th Oct 2017, 9:34 am   #33
crackle
crackle's Avatar
Hi Mike
If the STC edge meter in post #12 is still available, I would like to add it to my museum.
Thanks
Mike
BVWS Member
The KB Museum
My collection in the Radio Museum
crackle is offline
Old 24th Oct 2017, 8:27 pm   #34
Cobaltblue
Cobaltblue's Avatar
Hi Mike
No one else has claimed it so its yours
The Meter is OK but the internal multiplier is OC
Mike T
Mike T BVWS member.
www.cossor.co.uk
Old 24th Oct 2017, 11:02 pm   #35
els1967
Hi Cobolt, is the one in pic DSCF4768.jpg still available? I'm not v. technical so I'm having a bit of trouble following what's gone or not. Thanks
els1967 is offline
Old 27th Oct 2017, 9:12 pm   #36
gezza123
gezza123's Avatar
Originally Posted by turretslug View Post
Post 17, 1st picture top LHS corner (Square 4-hole case, RHS zero- at least assume it's that way and not stuck or broken!)
Hi Colin Turretslug. hope you don,t mind me asking when you get the above and you have looked at it, is there any chance you could do a scan of the dial face for me I have been looking for this for a while it was made by Q-Max for Berry,s S.W.ltd High Holborn WC1 and was fitted to the AR88 complete with a backplate.
I have the meter and backplate but not the correct dial. thanks gezza123
gezza123 is offline
Old 28th Oct 2017, 10:00 am   #37
turretslug
Sure thing, yes, I'll be liaising to pick up the meter in question at the December RWB event, so I'll get a good-res scale scan for you,
Colin
Old 29th Oct 2017, 1:45 am   #38
Karen O
Karen O's Avatar
Do I spy one of those edge-on battery/record level meters?
I could make use of those!
Karen O
Does Dr Who use Old New Stock parts for his/her Tardis?
Karen O is offline
Old 30th Oct 2017, 12:35 pm   #39
gezza123
gezza123's Avatar
Thank you very much Colin/Turretslug, I will look forward to to seeing that gezza123
gezza123 is offline
Old 30th Oct 2017, 12:37 pm   #40
Cobaltblue
Cobaltblue's Avatar
I have been a bit busy over the last week but I hope to get to the backlog on this this evening apologies to everyone awaiting a reply
Mike T
Mike T BVWS member.
www.cossor.co.uk
Copyright ©2000 - 2020, vBulletin Solutions, Inc.
Copyright ©2002 - 2020, Paul Stenning.
