13th May 2017, 2:33 pm | #1 |
Burndept 290 rewiring question.
I'm about to start a rewire on an old Burndept 290 as everything on this set has perished but these days the selection of color cables available seems very limited.
What ampage/voltage rating cable would the group recommend using for this set particularly for six way cables up to the loudspeaker and also the magic eye? |
13th May 2017, 4:54 pm | #2 |
Re: Burndept 290 rewiring question.
Ordinary 16/0.2 will be fine for most connections in a normal radio; it's only carrying a few tens of milliamps a few tenths of a metre with a few hundred volts across it. Even the parallel-wired heaters of a transformer-fed set only draw a couple of amps, and the hungriest valves -- the rectifier and output -- are too close to the transformer for any voltage drop to be significant.
13th May 2017, 5:19 pm | #3 |
Hi NC
You're welcome to this bunch of cables there are 10 different colours and I think they are all over a metre long. Not sure of core size but I am pretty sure more than adequate for the insides of a domestic radio Cheers Mike T
15th May 2017, 10:41 pm | #4 |
Thank you both for your help and advice. Indeed yes the cables will be very useful, thank you.
Can you please PM me Mike with either the collection or postage details? john |
