2nd May 2017, 9:08 pm | #1 |
Anyone knows what radio is this?
Dear People
Any one knows what radio is this? and who sells parts for it? I understand that uses an external battery, can someone confirm this please. Thank you. |
2nd May 2017, 11:13 pm | #2 |
Re: Anyone knows what radio is this?
I've not seen anything quite like the model, and I'm pretty sure it won't have been marketed in the UK at all, but the battery connector looks like a type that was used on various American "farm radios" as well as larger portables -
http://img.photobucket.com/albums/v3...oneBattery.jpg Paul |
2nd May 2017, 11:42 pm | #3 |
Parts will be standard electronics components for which modern equivalents or old stock (in the case of tubes) will usually be available. From where (in Honduras) I've no idea but generally Ebay will have sellers offering something suitable, provided that you know what you actually need.
Otherwise mainstream distributors like RS components, Mouser, Digikey etc will have modern resistors and capacitors etc. If you can provide details of all the tubes used in the set, it may be possible to trace a Philips schematic for something similar...... TBH the set looks "odd". There's a magic eye bezel at the front but they're unusual on a battery set. Is the chassis actually right for the cabinet? The mixture of octal and more recent tubes is also odd for Philips who generally fitted matching sets of their own brand tubes.
....__________ ....|____||__|__\_____ .=.| _---\__|__|_---_|. .........O..Chris....O Last edited by Herald1360; 2nd May 2017 at 11:54 pm. |
3rd May 2017, 12:13 am | #4 | |
Speaker not in correct place, it is on top of where the magic eye should be. Possibly unknown 1930s chassis in a late 1950s Philips cabinet. Should be possible to get going but is it worth it? John. |
3rd May 2017, 2:06 am | #5 | |
The EIA number is 274, which is RCA's number. Looks like a Frankenradio. |
3rd May 2017, 1:56 pm | #6 |
Be interesting to see if it could be made to work and what it sounds like.
Least its not a complete horror to look at like some franken radios. |
4th May 2017, 12:06 am | #7 |
The battery plug is the standard B4 type used on EverReady and Drydex combined HT + LT batteries. My guess is that it is an early 1950s European set which uses a DM71 magic eye which Philips were found of using in their quality battery sets!
Out of interest, what is the remaining valve line up? Regards Trevor. |
4th May 2017, 12:32 am | #8 | |
I'm not certain, but the pin spacing doesn't look like B4 to me - the axis of symmetry appears to be between the pins as in the link I gave above, and incidentally as in the plug used on smaller British HT/LT batteries, rather than passing through two of them as in the B4. Paul |
4th May 2017, 1:38 am | #9 |
That is a plug used for a 759 farm pack. A real big'un.
Just playing with high voltage.... |
4th May 2017, 10:06 am | #10 |
I don't think we ever used those here.
The OP is in Honduras, so the cabinet may have been made by Philips Eindhoven for export, or it may be a model from one of the Philips South American subsidiaries. There may be some connection with the Netherlands Antilles or Surinam. The internals are probably American, but this is all guesswork. |
5th May 2017, 3:26 am | #11 |
The valve line up, appears to be, US types, left to right, 1A7GT, 1N5GT, the miniture a 1U5 or 1S5 and output a 1Q5GT, 3Q5GT or a 1A5GT.
Those valves were not used in current production US sets, that late. Looks to be built in later 1951. |
5th May 2017, 6:41 am | #12 |
The OP has not come back to us yet but as the chassis is wrong, what are the piano keys doing and the concentric controls, are they just for show?
5th May 2017, 10:04 am | #13 |
A KR output valve there, Czech made, formerly Tesla? They claim high-end properties for audio enthusiasts, it seems?
Al |
5th May 2017, 10:51 am | #14 |
K-R Tubes Inc, made in USA.
Lawrence. |
10th May 2017, 3:55 am | #15 | |
Commercial operations meaning an office that not only sold but also specified and sometimes partially designed models for the local market and regional export, often sourced from their own or nearby Philips factories. This corresponds to the country letters used up to 1966 and the country numbers from 1966 on in the model designation. |
10th May 2017, 8:58 am | #16 |
10th May 2017, 9:06 am | #17 |
The piano keys appear to be On/Off plus five wavebands. I can't work out which wavebands from the pic.
10th May 2017, 9:12 am | #18 |
K-R tube entry in radiomuseum, mouse over pic for more detail:
http://www.radiomuseum.org/dsp_herst...ompany_id=9246 Lawrence. |
10th May 2017, 9:30 am | #19 |
Hello.
I am not a member of radiomuseum so unable to check any references. KR are a long established manufacturer of valves and took over Tesla production after the Velvet Revolution. Tesla now seems to be a US car manufacturer. Over the years I have seen many instances in mining equipment of the U.S. using established foreign companies names with an added hyphen or comma. As far I am concerned KR is a Czech company. |
10th May 2017, 9:37 am | #20 |
I've no wish to argue, all I'm saying is the K-R tube in the OP's pic was made in the USA because that's what's printed on it.
Lawrence. |
