13th Jan 2021, 11:40 am | #1 |
Component wax
Is the wax used on coils etc. ordinary bees wax? I have some wound components that I want to to tidy up and re-dip. In the past I've used candle wax diluted with a little olive oil (!) as it sets too hard and flaky otherwise, but I doubt that's an ideal combination.
Thanks Ian |
13th Jan 2021, 1:17 pm | #2 |
Re: Component wax
Bees wax is good. It does need to have the moisture driven out for electrical use by heating to just about melting point, (dont overheat!), and kept at that temperature for a couple of hours.
Beeswax is firmer than candle wax, and will withstand higher temperatures, paraffin wax or tallow isn't ideal for electrical work. |
13th Jan 2021, 1:20 pm | #3 |
Re: Component wax
I assumed it was paraffin wax owing nothing to bees. I wonder if that wax used to cover individual small cheeses is a suitable substitute - it comes in several colours
- Julian It's good here |
13th Jan 2021, 1:24 pm | #4 |
Re: Component wax
Softens at very low temperatures and has a high moisture content, probably just refined tallow.
13th Jan 2021, 2:05 pm | #5 |
Re: Component wax
I got SWMBO a candle making kit for Christmas, it contains soy wax, I wonder if that would be better?
13th Jan 2021, 3:22 pm | #6 |
Re: Component wax
13th Jan 2021, 10:58 pm | #7 |
Re: Component wax
Oil based polyurethane varnish? It is water repellant and harden well to fix coils. It is known not to affect the Q much. Buy a cheap set of small paint brushes from a pound shop as the brush has to be thrown away for single application.
13th Jan 2021, 11:16 pm | #8 |
Re: Component wax
Carnauba wax? An artist friend gave me a block of this he'd used for modelling. It's good for recoating old components because it's stickier and more flexible than paraffin wax.
The Waves That Rule Britannia |
