16th Jul 2018, 4:24 pm | #21 |
Re: Cleaning sticky goo off Drive surfaces
Acetone here, the goo is a nightmare sometimes once it is off it can get everywhere.
Gary |
16th Jul 2018, 4:35 pm | #22 |
Thanks, everyone for your suggestions. I'll try some Cream Cleaner, and maybe other things. Not been in the workshop since last Friday, so still have that ***** job to which to look forward!!
16th Jul 2018, 7:04 pm | #23 |
Where the affected parts can be removed well away from anything sensitive, I have used dry earth to absorb the bulk of the goo. Using something like a cocktail stick, the earth and goo can be worked into a stiff paste that is easier to deal with and doesn't stick to other things. Not appropriate for treating stuff in situ where there are things that might be damaged by the powdered earth. The soil here is a very fine loess-type brick earth that makes a very fine powder when dry. Bentonite (as used in home brewing for finings) is a highly absorbent mineral and should be effective.
16th Jul 2018, 9:09 pm | #24 | |
I still say Swafega hand cleaner is far better than all the nasty flammable volatile solvents. Mike |
17th Jul 2018, 10:35 pm | #25 |
Swafega is good.
Acetone is powerful stuff also, but as said, any plastic parts that get even a sniff of it will be ruined in very short time, so best only used on metal parts that have been removed from the machine unless you work very carefully with them still in place. As for Acetone being "Highly Flammable" - I remember quite a few years ago working with an 'old time' chemist who got very angry when safety inspectors had insisted that he kept the large stock bottles of Acetone in the already very crowded 'Flammable Cabinet' and not on the ordinary shelf with the other non-flammables. To prove his point I remember him filling a dish with Acetone on the table and chucking a lighted match into it. there was very little drama and I think the match went out the first time. It does burn, but really needs a 'wick' to burn properly, so yes it is flammable, but the 'highly' bit is probably a little debatable, but rules are rules. There's probably more danger from the combustible properties of all those 'wireless magazines' and stacks of printed off paper circuit diagrams that everybody has, not to mention that can of petrol that you keep for the lawn mower (and that really IS "HIGHLY flammable"), than there would ever be from a small bottle of Acetone. |
18th Jul 2018, 5:00 am | #26 | |
I've had to strip down tape recorder motors because the goo has got into the top bearing. No amount of external cleaning would get it to turn freely again. It gets on your hands and will finally disappear after washing your hands a few dozen times. It gets on your clothes and never totally comes off. Some manufacturers used belts that turn to goo (Philips are well-known for this), others used belts that just dry out and break. Does anyone know what the 2 types are made of? |
18th Jul 2018, 8:33 am | #27 |
I have just tested the flammability of Acetone.
With a capful of acetone in a shallow metal dish, it burst into flames with a pop whilst the match was about an inch above the liquid. I dont know what was in that chemists bottle but modern Acetone is highly volatile and burns like fury. So I would class Acetone as HIGHLY FLAMMABLE, be careful if using it. Mike |
18th Jul 2018, 8:57 am | #28 |
I've managed to remove about 98% of the goo from both motor pulleys and other drive surfaces using cream cleaner and IPA. I don't think any cleaning fluids have penetrated the top bearings of either motor as I held the motors horizontally whilt cleaning the pulleys, so, hopefully, once I fit a new set of belts, both decks will work O.K.!
