18th Mar 2020, 9:55 pm | #1 |
Cossor 483
Hi all trying to find out what I replace this capacitor with c33. It is huge says its 2 mfd. Why is it so big, I know the old capacitors are much bigger but I have never seen a paper capacitor that big
Mark |
18th Mar 2020, 10:12 pm | #2 |
Re: Cossor 483
Hi Mark, it's a pre WW2 set and I guess it was the best that technology of the time could achieve using metal foil and waxed paper dielectric. Also it appears to be across the HT supply so is large enough to withstand the voltage (at the time, probably not any longer!). You could restuff it but it's a messy business. If it were me I'd disconnect it leaving it physically in place for appearance's sake, and conceal a modern miniature component (rated at least 1.5 times the max HT voltage) behind it. The type of replacement capacitor doesn't matter much, electrolytic, polyester or whatever. Cheers, Jerry
18th Mar 2020, 10:25 pm | #3 |
Re: Cossor 483
It's a battery set and it's HT decoupling.
As the HT battery ages its internal impedance increases making motor boating more likely. You can use an electrolytic if you don't have a suitable polyester cap. Nice set. Cheers Mike T
18th Mar 2020, 11:14 pm | #4 |
Re: Cossor 483
If you want something modern and similar in size, a metallised polypropylene 2uF 450V motor run capacitor could be a good bet.
Something like this: https://www.ebay.co.uk/itm/2uF-Motor...QAAMXQ1PNRZkA0 Wrapped in some brown waxed card it would look the part quite well too or it would probably fit inside the old case with a bit of suitable potting compound.
18th Mar 2020, 11:29 pm | #5 |
Re: Cossor 483
Would this be ok. mind you that looks a good idea chris.
19th Mar 2020, 9:15 am | #6 |
Re: Cossor 483
Would anyone have a good copy of the data sheet on the back card that gives you the battery set up
19th Mar 2020, 10:39 am | #7 |
Re: Cossor 483
Function wise it would be fine. It's your choice for appearance.
19th Mar 2020, 11:30 am | #8 |
Re: Cossor 483
19th Mar 2020, 12:19 pm | #9 |
Re: Cossor 483
there are two GB taps -4.5 and -9V the -4.5V goes to the output valve grid Via the audio auto-transformer and the -9V goes to the front end gain control via the band switch.
I have a 483 but not sure where it is and how accessible. Cheers Mike T
19th Mar 2020, 2:25 pm | #10 |
Re: Cossor 483
I have to work out all the voltages yet and work out all the paper capacitors and valves. I have had to paint strip the varnish which I believe was put on like some sort of film the wood is a cheap ply with no grain, I have had to hand paint the wood which I'm pleased with my first time at this. I have checked the resistors and they are almost correct, all the cables are hard and need replacing
Mark |
19th Mar 2020, 2:54 pm | #11 |
Re: Cossor 483
These cabinets are white wood.
The Burr Walnut pattern is added by a photographic process. If you strip the finish you will end up with white wood. Eventually I am going to have a go at the photographic process but its way down my priorities at the moment. These looked great when they were new but its a really cheap cabinet. Personally I like the 48 and 58 series sets the big oversize dials appeal to me. Cheers Mike T
19th Mar 2020, 3:59 pm | #12 | |
Re: Cossor 483
It's big because that was the technology of the time. You have presumably not seen inside a 1950's TV with an original boost capacitor still fitted. some of them were 1.5uF at 600V.....now they WERE big!
19th Mar 2020, 4:22 pm | #13 |
Re: Cossor 483
Yeah mike t that's what I ended with white wood but I got gel stains and painted the effect back on then varnished over that when dry well I'm happy with how it looks I couldn't leave it as it was to bad
19th Mar 2020, 5:23 pm | #14 |
Re: Cossor 483
Incredible work, Mark, brilliant result.
19th Mar 2020, 6:02 pm | #15 |
Re: Cossor 483
Thank you nick. I am just ordering the capacitors that I will need. I can order most of the capacitors apart from
c7 = 0.25uf C31 = 0.05uf Is there a equivalent to these in axial |
19th Mar 2020, 7:23 pm | #16 |
Re: Cossor 483
C7 0.22uf C31 0.047 Are the modern equivalents
Cheers Mike T
19th Mar 2020, 11:31 pm | #17 |
Re: Cossor 483
Thanks mike
22nd Mar 2020, 7:34 pm | #18 |
Re: Cossor 483
I was looking at replacing the wires and have noticed the they are not multi strand wire but a single thick gauge wire the shielding is all brittle and falling off what would be best to do with this
There is a .0005mfd maca capacitor broken that goes to the aerial socket what should I use for that one |
22nd Mar 2020, 8:17 pm | #19 |
Re: Cossor 483
Use a modern silicon of the correct thickness multi strand or not if it looks ok.
22nd Mar 2020, 9:34 pm | #20 | |
Re: Cossor 483
Hope this helps....
