31st Dec 2019, 4:02 pm | #21 |
Defiant MSH902 addendum
Having completed this restoration some time earlier this year I thought I would fire up the radio over the Christmas period just to make sure everything was ok. It was, for about 20-30 minutes, then gradually started to lose the bass notes & grow quieter. This was something I thought I had fixed previously but obviously I hadn't!?! As this set doesn't have any circuit diagrams available (apart from my own hand written ones) & dozens of photos I took prior to any work being carried out I thought I'd spend an hour or two correllating the two. It wasn't unitl I had the chassis out of the case (again) that I was idly prodding around the resistors attached to the FC4 valve that I found a dodgy reading. There was supposed to be a 500K strapped across pins 2 & 6 (g1 & k), mine was reading 50K! This was a case of mistaken identiity, entriely my fault but a quick glance & it "looks" like a 510K. The body is painted a brick red & the gold tolerance band looks yellow under anything but a bright white light. Needless to say the orange band is nearly invisible against the body. I changed it for the correct value & now the set is booming nicely & has been for well over 3 hours, looks like the FC4 survived. Tough things these valves!
The difference between stupidity and genius is that genius has its limits. (Einstein) |
31st Dec 2019, 4:33 pm | #22 |
Re: Defiant MSH902
So what was the correct value?
Lawrence. |
31st Dec 2019, 6:05 pm | #23 |
Re: Defiant MSH902
500K Lawrence. Have a good evening & New Year.
31st Dec 2019, 6:32 pm | #24 |
Re: Defiant MSH902
9th Jan 2020, 9:34 pm | #25 |
Re: Defiant MSH902
Yes it does but I've been going through the photos I took before any work was carried out & the original resistor was a 500K across pins 2 & 6. I've also been looking through various other schematics of radios that use the FC4 (theres a fair few!) & the highest value I've found in those was 100K in an EKCO set. Unlike the valve museum datasheet the Defiant has that 500K across 2 & 6 but also a 250R with 0.1uf in parallel to chassis from pin 6 (k). I don't have enough knowledge of valves to unpick the designers thoughts on this one but the radio now works as it should. I'm sure there are other members who may shed some light on this toothsome feature.
10th Jan 2020, 3:46 pm | #26 | |
Re: Defiant MSH902 addendum
A 500k (ish) resistor going down to 50k in that circuit position I find very hard to believe unless it's had the wrong colour code painted on it.... I suspect the original that was fitted was either a 50k or 56k, I would go for 50k. Lawrence. |
15th Jan 2020, 8:14 am | #27 |
Re: Defiant MSH902
Can you advise the contact details for the co-op archive as I am looking for a circuit for a Defiant MSH547. Thanks
15th Jan 2020, 1:48 pm | #28 |
Re: Defiant MSH902
The Avery Man,
The email address is on the Co-Op Archive website but does take a little rooting around to find so here it is: archive@co-op.ac.uk When I contacted them their reply was as follows: "I am afraid we do not have service sheets for any of the radios before the 1950s. The collection of material we hold on the CWS manufacture of radios and televisions is small and includes some catalogues of products from the 1930s. There are also handwritten notebooks with information about individual models. These show that the Model MSH 902 came in two versions - AC and AC-DC and were first introduced during the 1935-36 season." I'd have said that you may find yourself in the same position as myself, no circuits other than what you may be able to come up with, I have looked on my copy of the Vintage Radio Service Data DVD & there's nothing there either. Best of luck sir!
18th Feb 2020, 9:40 pm | #29 |
Re: Defiant MSH902
Final (hopefully!) addendum to this thread. This radio has always had a rustling noise in the background on MW/LW, sometimes there would be an odd phasing then back to normal or random pops/clicks. I, in my ignorance, thought initially it was simply down to the age of the valves and/or coils, after all it is nearly 90 years old having been manufactured in around 1933-34. To have some noise would be forgiveable BUT it was irritating! Then I started trawling through this forum & others for the possible causes of it. It took many hours of reading but finally a trend began appearing especially in America of all places. It would seem the mica capacitor is suffering the effects of time. I then found a paper published in 1960(!) giving a LOT of detail as to their failure modes, one of which is silver migration & inclusions in the mica itself. I'm not at all sure if the document is still within copyright so I have not attached it here. The link is: https://www.google.com/url?sa=t&rct=...10e6UqL2TWJLvf
Anyway, I was becoming more convinced this was perhaps what was still wrong with the Defiant. I remembered I had left one mica capacitor in the aerial side of things. Out came the chassis, it looked good, tested ok as well, bang on value. Grab a replacement from the stock of caps, out with the old & in with the new! Switched on, the rustling/popping/f*rting had gone! It sounds so much better.
20th Feb 2020, 8:07 pm | #30 |
Re: Defiant MSH902
I've seen a few videos of restorers in america talking about problems with silver-mica capacitors, (eg rustling and crackling); I've never experienced it in UK sets and assume its a US problem; so well done for tracking it down!
Defiant have a special allure for me due to the well-known background behind the name and operation; their well-made, honest Plessey chassis and cabinets that have that ivorine 'CWS Cabinet Works' label and the (often) high-art-deco designs. Yours is lovely, BTW
Kevin |
21st Feb 2020, 11:20 pm | #31 |
Re: Defiant MSH902
Nice! Please post more photos when you have time. It is from the same year, 1934, as the HMV-468 I'm refurbishing.
24th Feb 2020, 8:59 am | #32 |
Re: Defiant MSH902
I'd be glad to post some pictures as & when time allows. Despite there being virtually no technical information for this set it remains one of my favourites, its quite a large set but back in the day it would have been considered as furniture as well therefore had to "look the part". I have to run this one via a pantry tx as locally we have virtually no AM stations that are clear. Even R4 on LW is swamped by SMPS/LED lighting etc. Come to think of it, some FM stations struggle too! I'd read that silver migration is an issue in the states but hadn't read of many here in the UK. I'm glad I found out about it as I've got a Philco radiogram (approx. 1933ish) under the knife & will be watching out for that. Have a good day one & all.
26th Feb 2020, 6:14 am | #33 |
Re: Defiant MSH902
Indeed, some of these radios are now old enough that mica capacitors are failing.
Silver migration / whiskers is indeed a problem, mainly in slug tuned (adjustable inductance) IF transformers which have the capacitors built-in. Those can usually be repaired by cutting out the original capacitor(s) and installing a new one(s) under the chassis. |
26th Jul 2020, 3:29 pm | #34 |
Re: Defiant MSH902
Last time I'll post on this radio, hopefully. Since the last post it developed yet another fault, after about 4-5 hours the audio would become quieter & distorted. On GRAM it wouldn't do this, that eliminated the output stage & speaker, phew! After much measuring I'd found exactly nothing wrong, voltages around about what I'd expect by looking at the valve datasheets. There are no diagrams or technical documents for this model. It was by accident I switched from MW to LW with the chassis on the bench looking underneath & noticed some sparking/tracking on the multi way switch. This thing is a monster, 10+ sections, made specially for this radio, to replace I would imagine would be possible but very time consuming, yes it could be hard wired but not something I'd feel comfortable about doing. A few more measurements (MEGGER on 100V range & all valves out) confirmed leakage between several sections to its metalwork, one or two down in the 30-40K region. I had taken this switch out initially & took it to work to get a really good look at it, obviously I failed! It looked like old grease/oil/dirt/dust between the paxolin seperators on the sides of the assembly that were causing the tracking issue. After much swabbing with acetone & cotton buds, light abrasion with a dremel on the carbonised parts & then seal with conformal coating, the MEGGER readings were up in the 100M region, much better. Put all the valves back in then switch on. Tuned in to the pantry TX with no input to get a silent carrier. Background noise greatly reduced, add in some music, overall sound improved, better all round. Its been running for the best part of the day now & sounds just great. This radio really has given me the run around but in the nicest possible way & its taught me a thing or two.
