Old 8th Jul 2021, 11:57 am   #21
Jon_G4MDC
Jon_G4MDC's Avatar
Default Re: Severe MW interference solved
An interesting new topic has developed here - can an incandescent lightbulb oscillate and produce RF?
There are some posts in the foregoing which clearly show LEDs - these are something entirely different. The Ofcom report showed a filament bulb (below) being held to be responsible for interfering with airband.
I would like to continue that discussion in another thread. I have some almost identical bulbs on which I might try experiments. It doesn't belong here in Vintage Radio (domestic).
Mod's please could you oblige? thanks.
Jon_G4MDC is offline
Old 8th Jul 2021, 12:54 pm   #22
Radio Wrangler
Radio Wrangler's Avatar
OK, a new thread opened for RF from incandescent filament bulbs.
https://www.vintage-radio.net/forum/...d.php?t=181759
I've put nothing other than an intro in it, because if I did, the forum software would position it ahead of the intro... it's very punctilious about timestamps!
I think your thread has come to a satisfactory conclusion, but anything on filament bulbs should go in the new thread where it can be found by searchers.
Last edited by Radio Wrangler; 8th Jul 2021 at 8:13 pm. Reason: url for new thread fixed
Radio Wrangler is offline
Old 8th Jul 2021, 1:44 pm   #23
McMurdo
McMurdo's Avatar
I assume branded led bulbs are compliant with relevant RFI standards, but suppose directly imported online bulbs simply don't bother.
A takeaway in a neighbouring town has recently decorated their front window with LED strips including an 'OPEN' led sign and when I drive past it makes my car radio erupt in whistles and buzzes, and that's on FM.
Kevin
McMurdo is offline
Old 8th Jul 2021, 6:58 pm   #24
Jon_G4MDC
Jon_G4MDC's Avatar
Thanks for opening the new thread requested David.
I'm not sure why the link behaves the way it does.
When I click it it behaves as if it's me that is posting a new thread. Was that as it should be?
I can't see any intro. tnx
Old 8th Jul 2021, 8:15 pm   #25
Radio Wrangler
Looks like my fault. I was creating the new thread in a separate window and I guess I must have not saved it before closing. Thread created and the url in post above has been edited. Sincere apologies.
Old 9th Jul 2021, 8:21 pm   #26
bobhowe
bobhowe's Avatar
Hi. I've been very lucky with MW interference regarding LED light bulbs as I use Philips Hue, hope I don't go OT. The worst thing I have had causing interference is a variable temperature soldering iron, wipes all of MW when switched on and an AAA battery charger, hissing when switched on.
Kind regards, Bob.
bobhowe is offline
Old 21st Jul 2021, 9:27 pm   #27
clockman
As re my early thread the level of interference in my house is very high in most parts so today i had a thought i took one of my repaired Vidor Lady Margaret CN429 battery radios down my large garden and tested it on M/W & L/W the reception was crystal clear on all stations no interference so maybe i should do it with all my sets to test there sound quality. Just a idea.TAB
clockman is offline
