Old 30th May 2021, 8:25 am   #1
Martijnvanhooff
Default Choke supressor in Wolf Cub Drill
Hi all,
I found a nice old Wolf Cub Drill in the thrift shop.
I made a mistake while taking the drill apart, I thought someone else did a revision and thought it was a heat shrinking tube instead of a suppression choke.
I think this is exactly what Johnnie dit in this thread: HERE.
I tried reopeing the thread, but I am not able to do so.
I am wondering why G6Tanuki advised to buy this one.
buying only this component is quite expensive (shipping costs to NL, and minimum of 5. Moreover, I don't own a company which is needed to order).
This one is a 10uH 3Amp, but how do I know if this is the correct one (there are a lot of cheaper ones from 10uH but with varying Ohm, mHz and A).
Hope somebody has an alternative !
Martijnvanhooff is offline
Old 1st Jun 2021, 9:06 pm   #2
John_BS
John_BS's Avatar
Default Re: Choke supressor in Wolf Cub Drill
The precise value is not critical.
Can you let us know the approximate size of the part you're replacing (length/diameter).
John_BS is offline
Old 1st Jun 2021, 11:50 pm   #3
Herald1360
Herald1360's Avatar
I don't think you have to be a company to order from RS these days, at any rate you don't in the UK. Anyone's money will do!
The same part is available from RS Netherlands:
https://nl.rs-online.com/web/p/leade...ctors/8807161/
which might make the total costs more palatable.
....__________
....|____||__|__\_____
.=.| _---\__|__|_---_|.
.........O..Chris....O
Herald1360 is offline
Old 4th Jun 2021, 10:27 pm   #4
Martijnvanhooff
Sure!
Choke
and diameter 4-5mm
Old 5th Jun 2021, 8:10 am   #5
Martijnvanhooff
Hi,,
Sorry for the late response!!
Its 10mm in length and +/- 4mm diameter.
attachement of one I did not break ;-)
Old 7th Jun 2021, 8:40 am   #6
Martijnvanhooff
what about this one?
Old 8th Jun 2021, 6:49 pm   #7
greenstar
greenstar's Avatar
Martin, I have a wolf cub, and it's a great drill. I have one or two, including a DeSoutter which I like. I always use them with an rcb, just in case. I find then surprisingly ergonomic in shape. They are my usual drills for small work needing a bit of torque, but I also have an older Bosch battery drill, that had a flat battery pack, and cost me nothing, which i use corded with a 12v battery.
Tony
greenstar is offline
Old 8th Jun 2021, 7:15 pm   #8
John_BS
John_BS's Avatar
It would work, but much larger?? Is there room?
John
John_BS is offline
Old 12th Jun 2021, 6:50 am   #9
Martijnvanhooff
I am quite sure it will fit.
But to be safe, will such inductor also do the job?
I can't find the other specifications such as the amperage, also not by looking up the part numbers...
https://www.amazon.co.uk/10-10uH-Axi...bb_marketplace
