Old 10th May 2021, 5:08 pm   #1
els1967
Default Mains transformer wanted
Does anyone have a tran. they could sell me that does 230v to anywhere between 36v to 50v? Two would work ok if they both add up to that range. Can collect if in reasonable range, say about 30 miles. I'm Luton way.
Thanks.
els1967 is offline
Old 10th May 2021, 5:09 pm   #2
Default Re: Mains transformer wanted
Current required?
Keep the soldering iron hot.
Station X is online now
Old 10th May 2021, 5:09 pm   #3
barrymagrec
Current?
barrymagrec is offline
Old 10th May 2021, 5:17 pm   #4
els1967
Ah soz not sure. It's only needed to ring the bells on a few series 300 GPO phones, so not much I would imagine.
els1967 is offline
Old 10th May 2021, 8:08 pm   #5
merlinmaxwell
merlinmaxwell's Avatar
I thought 'phones used 16Hz for the ring.
merlinmaxwell is online now
Old 10th May 2021, 8:13 pm   #6
els1967
50Hz Mains through a tranny is ok if you're not a purist. trying to replicate 16hz starts to get quite complicated. I tried using a couple of relays and a 555 with a d-type flip flop reversing DC between the two relays to the bells. but it didn't really work that well, ok I guess. Works enough for a doorbell. Probably there are better ways to do it.
els1967 is offline
Old 11th May 2021, 1:02 am   #7
Glowing Bits!
Glowing Bits!'s Avatar
Most GPO bells will work at 50Hz but will involve having to sort out the core spacing, this involves a feeler gauge and a spanner, instructions are available online as to how to do it.
Rick, the annoying object roaming the forum.
Glowing Bits! is offline
Old 11th May 2021, 2:15 am   #8
Refugee
Refugee's Avatar
I would use an old audio amplifier and sine wave oscillator.
Refugee is online now
Old 11th May 2021, 8:41 am   #9
pip5678
pip5678's Avatar
I think I may have a Converter Ringing No 7 if that would suit https://www.britishtelephones.com/conring.htm PM if interested.
pip5678 is offline
Old 11th May 2021, 1:13 pm   #10
pip5678
pip5678's Avatar
Ringer No 7 now found and done a quick test to confirm operation.
ID:	233766   Click image for larger version
pip5678 is offline
Old 14th May 2021, 8:07 pm   #11
Ed_Dinning
Hi Folks, mention of ringing at 16Hz led me to an article in Electronic Engineering for April 1949. This uses ferroresonance principles to generate sub harmonics of the supply frequency,. by using saturating iron cored inductance's .
Illustrated is a ringing generator convertor by the Telephone Manufacturing Co Ltd.
This is also cross referred to in the POEEJ, p110 jan 1944.
Ed
Ed_Dinning is offline
Old 15th May 2021, 1:46 pm   #12
els1967
All sorted - thread can be closed.
els1967 is offline
