Old 7th Oct 2010, 1:53 pm   #1
Skywave
Question "Tester RP 3045"
I recently acquired a box of vintage radio bits at a car boot. Amongst the items was found a Bakelite label with the legend "TESTER RP 3045 DGM.RPW 3045D"; obviously ex-military / M.o.D. The label is about 1½" x ½", for securing to a front panel (?) with csk. 6BA screws (this bit is an inspired guess!).
Any ideas, anyone, as to what this item is / was . . . . . .
Al. / Skywave
Skywave is offline
Old 7th Oct 2010, 2:42 pm   #2
Station X
Station X's Avatar
Default Re: "Tester RP 3045"
Don't know what it is, but it's ex GPO/Post Office Telephones as denoted by diagram RPW...
Graham. Forum Moderator
Station X is offline
Old 7th Oct 2010, 11:17 pm   #3
Skywave
Arrow Re: "Tester RP 3045"
Ah! Thank you, Graham.
Amongst the rest of the bits was a peak programme meter (BBC style), an AC3/SP3, AC/VP1 and a D41 (diode) valve, an assortment of Rs and Cs (classic 1950's vintage), various chokes, LF and HF and other sundry bits; no mains transformer; no variable tuning condenser, no chassis metalwork.
It seems likely all these bits came from the one same stripped item. I suspect a test box for some sort of fixed channel HF communications circuit that used AM, e.g. a modulation level meter, portable, battery operated?
Just curious; I have no real 'need to know'. Any more ideas, chaps?
Al.
Skywave is offline
