Old 17th Sep 2018, 9:11 am   #1
DoubleWound
Default Interfacing Function Generator to Control Grids
I have recently acquired a Siglent SDG1020 Function Generator which has a minimum output of 4mVpp and variable load impedance settings of up to 10,000kOhm (plus "Hi Z").
Service sheets normally just say connect to control grid via a 0.1uF capacitor.
My questions to knowledgeable members are:
1. What is the best way to attenuate output voltage?
2. What is the best load impedance setting?
A resistor in series with the capacitor and Hi Z seems to work but I'm wondering if there is a more appropriate method.
My questions apply to both RF and audio control grids.
I have searched forums for a definitive answer and I apologise if this has been covered before.
DoubleWound is offline
Old 19th Sep 2018, 9:58 pm   #2
Chris55000
Default Re: Interfacing Function Generator to Control Grids
Hi!
A simple resistive potential divider is all that's needed up to the maximum o/p frequency of most F.G.'s – for this 20 MHz generator, if you use a 9k1 upper resistor and 910R lower resistor, you will get typically 0–400uV p–p output, whilst a 91k and 910R divider would give you typically 0–40uV p–p output – a lot less than many inexpensive meters, both standard DMM's and purpose–made audio electronic meters can read reliably – and you'd not be able to see a 0–40uV attenuated F.G.'s output with the average oscilloscope's amplifier with a 10mV/div max. gain setting – the "grass" present in the scope's amplifier would mask it!
(There are specialist oscilloscope Differential Amplifiers that will read down to 20/50uV/div but their bandwidth is extremely limited and they're notoriously difficult to use!)
The 0u1 (1000p in R.F./I.F. stages) mentioned in Service Sheets is simply a d.c. blocker to prevent any d.c. in the signal generator's output upsetting transistor or valve bias, and MUST be included with function or DDS synthesised generators – it is purely a safety component and serves no direct attenuation function.
Chris Williams
Chris55000 is offline
