Old 5th Sep 2018, 2:52 pm   #1
3Phase615V
3Phase615V's Avatar
Default Bearcat BC-220 FB
Hi all,
I was given a dead Bearcat BC-220 FB scanner several years ago, which I've just got around to checking. It looks like the transformer's primary winding is open circuit, hence showing no signs of life when powered on. It can be powered from an external 13.8V DC supply but for convenience I intend to repair the internal mains supply, if possible.
According to the service manual, the power specifications for the scanner are "117Vac 20W, 13.8Vdc 9W". Translating that to a 230VAC mains supply (UK) I presume the transformer wattage would be unchanged at 20W. My question is if I replace the internal transformer would a transformer with the following specifications suffice: 230VAC 20VA 8v-0-8V with tappings? The service manual states the output from the original transformer is 16VAC; however, there are three tappings soldered to the PCB, which I presume are 8V-0-8V.
Service manual: http://www.repeater-builder.com/unid...20-svc-man.pdf
Thanks
Ade
3Phase615V is offline
Old 5th Sep 2018, 5:32 pm   #2
Biggles
Default Re: Bearcat BC-220 FB
I hope somebody hasn't connected it to 240V instead of 115V and burnt out the transformer. That may have overloaded the radio circuit. Might be best to give it a check on 12V just in case the radio has been damaged before changing the transformer. You will need to half the value of the original mains input fuse if powering it from 240V instead of 115V. Check polarity of the 12V input socket as sometimes these were reversed. i.e centre pin negative not positive. I like Bearcat scanners. They seem to be well designed and perform well.
Alan.
Biggles is offline
Old 5th Sep 2018, 6:00 pm   #3
HamishBoxer
HamishBoxer's Avatar
It has been checked out 13.8V DC and appears ok.
HamishBoxer is offline
Old 5th Sep 2018, 6:04 pm   #4
JulietMike
JulietMike's Avatar
I have one of these which was supplied fitted with a 240V transformer for the UK. Output is centre tapped. There is a mod that allows switching between AM and FM.
John
JulietMike is offline
Old 5th Sep 2018, 7:33 pm   #5
Biggles
Whoops, mis-interpreted the remark on DC power.
Biggles is offline
Old 5th Sep 2018, 9:02 pm   #6
3Phase615V
3Phase615V's Avatar
Yes, sorry, perhaps I should have made it clearer that the radio is the 240VAC version, according to the two-pin power socket label. The radio appears to power on okay through the DC input at 13.8V but I've had to disassemble, clean, lubricate and reassemble the on/off volume and auto/squelch pots as they were both functioning poorly. The DC input is just a red lead to a positive spade connector input and a black lead to a solder tag on the case.
So regarding a replacement transformer, a 230VAC 20VA 8V-0-8V with tappings would be suitable?
That's interesting regarding the AM/FM mod. I'll take a look into that one once I've got the transformer sorted.
Old 7th Sep 2018, 2:38 pm   #7
orbanp1
Hi Ade,
A 8V - 0V - 8V transformer would give you only about 10.5VDC unloaded.
For 13.8VDC you would need something more like a 10V - 0V - 10V transformer.
Regards, Peter
orbanp1 is offline
Old 8th Sep 2018, 3:39 am   #8
Terry_VK5TM
Terry_VK5TM's Avatar
The mains transformer generates 16v DC unloaded according to the description in the manual, 8-0-8 or even 10-0-10 is not going to cut it.
You would be looking closer to 12-0-12.
This 16v is is not used to run anything directly in the rig, it is regulated to 5, 9 and 11v internally.
Terry VK5TM
https://www.vk5tm.com/
Terry_VK5TM is offline
Old 9th Sep 2018, 12:46 am   #9
3Phase615V
3Phase615V's Avatar
Thanks Peter and Terry. I can see that I mistakenly quoted the service manual stating 16VAC output from the transformer, which of course caused an underestimation of the transformer output.
I think I will go with a 12V-0-12V transformer as you've suggested, Terry, as, as a friend advised, some margin for ripple voltage would be wise.
Old 9th Sep 2018, 2:14 am   #10
Terry_VK5TM
Good luck, let us know how you get on with the repair.
Terry VK5TM
Old 10th Sep 2018, 1:29 am   #11
3Phase615V
3Phase615V's Avatar
Yes,will do. Thanks Terry and all.
