Old 10th Aug 2018, 10:44 pm   #1
CJK_303
Default Old Polish Portable Radio Modification
Hello everyone this is my first post ever. I wanted to share with you something I did with the shell of an old polish radio made by Unitra in the 1968. Kamila MOT-631-2.
I modified every single piece of it therefore I am aware that some people may not like it however, when I got this radio all that was left of it was the outside plastic shell, broken piece of plastic with the scale on it and a rusted and eaten away faccia plate.
https://image.ibb.co/eorb1U/radio1.jpg
I decided to modify the case in order to give the radio a new life. I filled in the holes on the sides of the case with epoxy and glass fiber then sanded down the epoxy evenly and then smoothened it out.
https://image.ibb.co/j2JCap/radio2.jpg
Then I took away the metal faccia part. Underneath it was rusty, corners were eaten away so I remade the missing bits with epoxy also.
https://image.ibb.co/jP5B1U/radio3.jpg
The case was empty. I didn't have the electronic bits only the plastic case so I decided to buy a modern welleman radio kit that I assembled because the dimensions were nearly perfect to fit inside the radio. I decided to use metal buttons and put them on top of the case to control the new electronics. So I made this template to cut holes :
https://preview.ibb.co/nq6qvp/radio4.jpg
https://preview.ibb.co/b3G7ap/radio5.jpg
https://image.ibb.co/bMFHap/radio6.jpg
Here it is with holes cut for the new buttons and a new retractable antenna.
https://image.ibb.co/nzqN89/radio7.jpg
I filled in the original screw holes. I decided to just glue this thing together when its finished to give it a smooth look.
I bought chrome plated buttons, a retractable antenna and a bunch of other bits I needed. Test fit :
[img]****************/fCv5T9[/img]
https://image.ibb.co/k7qVT9/radio9.jpg
After that I started to work on the faccia plate, i cleaned it up , removed the remains of the 50 years old net glued to the back of it, I got rid of the rust and I remade the missing parts using epoxy resin.
Here it is ready for chrome :
https://preview.ibb.co/cpo61U/radio10.jpg
https://image.ibb.co/kp3OgU/fr_146.jpg
I used vacuum metallization to achieve the chrome effect considering the fact that epoxy cannot be galvanized. Here is the result :
https://image.ibb.co/nmC5vp/radio11.jpg
https://image.ibb.co/cqHS89/radio12.jpg
https://image.ibb.co/kbGFvp/radio13.jpg
I made a battery compartment part inside of the case in the meantime before sending it over to be turned into "wood".
It turned out really beautifully. In the meantime i designed a new plate that would go in place of the original broken plastic bit with scale imprinted on it. I decided to make it out of brass, laser engrave it and then galvanize it in chrome. The new plate would just have icons that would show what each button does. Also I sent the case to have wood grain water transfered over it and lacquered. This is the result :
https://image.ibb.co/cChkT9/radio14.jpg
Below you can see the new chromed plate and the water transfer wood grain coated and lacquered case.
https://image.ibb.co/iKD9o9/radio15.jpg
https://image.ibb.co/nCVuMU/radio16.jpg
Assembly time :
https://image.ibb.co/iETygU/radio17.jpg
https://image.ibb.co/fC4zo9/radio18.jpg
And ITS ALIVE !
https://image.ibb.co/gLDvvp/radio19.jpg
https://image.ibb.co/dkLsap/radio20.jpg
https://image.ibb.co/iaJTFp/radio21.jpg
And a short little movie showing how it works and plays.
https://youtu.be/tXzGTal9mNw
CJK_303 is offline
Old 13th Aug 2018, 1:11 am   #2
retailer
Default Re: Old Polish Portable Radio Modification
Excellent job - how did you do the vacuum metallization ?
retailer is offline
Old 13th Aug 2018, 6:16 am   #3
kellys_eye
I suspect the metallization is done on a similar line to vacuum deposition of mirror surfaces on amateur telescopes. There are companies that will 'aluminize' telescope mirrors that would (should?) take on small jobs like that.
http://www.scientificmirrors.co.uk/aluminising.html
Pricing for plastic work should be considerably lower given the majority of mirror coating is spent cleaning and preparing!
kellys_eye is offline
Old 13th Aug 2018, 11:31 am   #4
retailer
Is it possible to do it your self as it looks to be a costly process compared to the cost of a new radio - then I guess it depends on how much one values the hobby.
I have a small kiln that I plan to use in model engineering for heat treating metal - I investigated quite a few diy kiln controllers based on Ardunio before finally deciding on a complete ready made kit for AU$16 (ex Hong Kong) PID controller, solid state relay and thermocouple - a basic Ardunio board is AU$16 ! why would any one go to the trouble of all that development when the complete kit is available at such low cost. I guess the answer is the same - how much do you value your hobby.
retailer is offline
Old 13th Aug 2018, 11:48 am   #5
Reelman
Reelman's Avatar
Welcome to the forum CJK_303!
That looks a great job and a good use for an old tired radio.
Peter
Reelman is offline
Old 13th Aug 2018, 3:22 pm   #6
David G4EBT
David G4EBT's Avatar
Welcome to the forum, and thanks for your impressive 're-purposing' of a radio that was past its best.
Very innovative, with several specialist techniques involved and a great end result.
The water transfer printing technique used to attain the woodgrain effect on the cabinet is interesting.
It goes under a range of titles - Hydrographics, immersion printing, water transfer printing, water transfer imaging, hydro dipping or cubic printing. It's is a method of applying printed designs to three-dimensional surfaces. Widely used to customise alloy car wheels, motorbike helmets & fuel tanks, cycle frames - even guitars, often with striking results. Some examples:
https://www.bing.com/videos/search?q...98&FORM=WRVORC
No idea how much it costs. Quite a lot would be my guess!
David.
BVWS Member.
G-QRP Club member 1339.
David G4EBT is offline
