13th Jul 2017, 7:20 pm | #1 |
Collaro ac544
Hi all, just picked up one of these and it runs, but only if I move the linkage by hand. Seems it is auto stop as there is a lug on the bearing housing under the platter that moves a bar with a roller on its end when the arm moves to the centre of the record. But I can't get the linkage to move the idler arm and switch. There are no levers as far as I can see so think it's supposed to move the linkage via the arm. Any help appreciated. Don't know how to post photos here
13th Jul 2017, 7:53 pm | #2 |
Re: Collaro ac544
That linkage operates when you move the tone arm to the right to start the turntable at the end it will auto-stop. That same linkage pulls the idler into contact with the inner turntable rim. You can download the Collaro diagrams for this via a google search. The switch on linkage should be light, otherwise the lightweight plastic tone arm can move on its mount.
Edward. |
13th Jul 2017, 9:44 pm | #3 |
Re: Collaro ac544
Thanks Edward, there is obviously something wrong as I have removed the arm and can turn the horizontal arm pivot easily with my finger and thumb but the mechanism doesn't engage the idler or power switch. I also removed the bearing housing from the platter so I can see what's happening and with the idler engaged I can turn the arm pivot as if the arm was moving to the centre it disengages. I did some searching but didn't find anything.
14th Jul 2017, 6:22 am | #4 |
Re: Collaro ac544
A couple of photos of your mechanism top and bottom will let us see what is missing.
14th Jul 2017, 8:17 am | #5 |
Re: Collaro ac544
ok so managed to add a thumbnail of the top side, will take a photo if the underside today.
14th Jul 2017, 11:41 am | #6 |
Re: Collaro ac544
Nothing missing there I see it is a 3 speed version so an fairly early version
14th Jul 2017, 12:48 pm | #7 |
Re: Collaro ac544
Uploaded photo of underside,
14th Jul 2017, 1:28 pm | #8 |
Re: Collaro ac544
14th Jul 2017, 2:20 pm | #9 |
Re: Collaro ac544
No you move the arm to the right away from the rest till it clicks
14th Jul 2017, 2:58 pm | #10 |
Re: Collaro ac544
ok I have moved it that way but no click, maybe I didn't give it enough force?
14th Jul 2017, 4:39 pm | #11 |
Re: Collaro ac544
Do you have the one piece or plug in head arm?
14th Jul 2017, 6:29 pm | #12 |
Re: Collaro ac544
Just see my earlier posts here - do be careful of stress on the arm in the pulling to the right switch on procedure.
Edward. |
14th Jul 2017, 9:47 pm | #13 |
Re: Collaro ac544
15th Jul 2017, 12:50 am | #14 |
Re: Collaro ac544
well done we all learn from others.
