7th Jul 2017, 9:50 pm | #1 |
Volume coming and going in one channel of a Decca SRG500 - suggestions?
This has just started happening on both radio and disc inputs. I tried changing the EL84, which helped for a bit - then the problem came back. Any pointers to caps with a criminal record etc. very welcome!
'....don't go mistaking Paradise for that home across the road!' (Bob Dylan) |
7th Jul 2017, 9:55 pm | #2 |
Re: Volume coming and going in one channel of a Decca SRG500 - suggestions?
Unless C43 is something like a Mullard Mustard it should have been changed.
If C48 is leaking it will change the bias on the pentode's control grid. A few voltage checks will tell you what's happening. EDIT. That circuit doesn't look right to me, but I'm sure someone will be able to explain how it works.
7th Jul 2017, 10:09 pm | #3 |
There's a horizontal resistor missing.
EDIT: Correction...an HT feed line missing Lawrence. Last edited by ms660; 7th Jul 2017 at 10:31 pm. |
7th Jul 2017, 10:37 pm | #4 |
Yup!
It's shown on the Trader Sheet.
8th Jul 2017, 12:03 am | #5 |
Many thanks gentlemen - those are the very fellows I suspected. There are other oddities in this circuit diagram (the trader sheet). The output valves (V5/6) are ascribed EL84 - but in the plan view (very helpful for an amateur like me, but in this case - a bit confusing) V5 is identified as an EL85!
