Old 9th Jul 2017, 4:08 pm   #1
jacob65
Default Garrard Spring
Hi, I have this nice at60, where the spring pulling the idler wheel seems like it has been streched at some point. The record player is a bit slow on start too. If anyone with a similar type of deck can check if this is normal that would be much help! Thanks
jacob65 is offline
Old 9th Jul 2017, 5:14 pm   #2
Edward Huggins
Default Re: Garrard Spring
Both springs look OK to me. Usually if there is a lack of tension, there's a gap where the spring should be compessed. Slow to start signals a lack of use and a need for lubrication. This is comprehensively covered in the Stickys up above (see GarrardAutoslim, SP25.)
Edward.
Edward Huggins is offline
Old 9th Jul 2017, 5:18 pm   #3
Which thread is that Edward? It helps if you post a link.
Station X is offline
Old 9th Jul 2017, 5:41 pm   #4
jacob65
Thanks, motor, idler wheel and bearing assembly has been cleaned and lubricated. Everything runs good.
jacob65 is offline
Old 9th Jul 2017, 10:44 pm   #5
Michael Maurice
Michael Maurice's Avatar
The one on the pulley bracket is very slightly elongated but as long as it works then leave it alone.
Forum Moderator
Michael Maurice is offline
Old 10th Jul 2017, 12:46 am   #6
RojDW48
RojDW48's Avatar
Probably stating the obvious unnecessarily, but you have cleaned and de-greased the inner rim where the idler bears?
'....don't go mistaking Paradise for that home across the road!' (Bob Dylan)
RojDW48 is offline
Old 10th Jul 2017, 8:18 am   #7
crackle
Now if that was a record player I was repairing, I would cut off some of the stretched coil and using thin nosed pliers make a new open loop to go over the idler hook.
Mike
crackle is offline
Old 10th Jul 2017, 12:33 pm   #8
Techman
Techman's Avatar
Seeing as the OP has stated in post #4 that he's cleaned and lubricated everything and it's all now up and running, then there's no need to start messing up springs, especially as the springs in the picture in the first post both look perfectly good to me - in my opinion, anyway.
Techman is offline
Old 10th Jul 2017, 5:46 pm   #9
jacob65
Yes I have years of experience with servicing these decks. But that springs just caught my eye, but I think I will leave as is until I get a hold on another at60 deck.
jacob65 is offline
