Old 17th Jan 2021, 7:25 pm   #1
Ted Kendall
Default 2SK23A equivalent?
This is a FET in a Sony (ALPS) FM front end I'm trying to subdue. Anybody know of a readily available equivalent? The usual sources aren't that forthcoming.
Ted Kendall is offline
Old 17th Jan 2021, 7:39 pm   #2
Restoration73
Restoration73's Avatar
Default Re: 2SK23A equivalent?
Towers lists BFW61 or 2N5459 - the latter is stocked by Cricklewood Electronics.
BF256 L versions have the same pinout d,g,s
Restoration73 is offline
Old 17th Jan 2021, 7:41 pm   #3
JonSnell
JonSnell's Avatar
NTE312. Replacement: 2SK23A. - JFET N Channel.
https://www.datasheetarchive.com/2SK23A-datasheet.html
It looks like Newark have some stock; https://www.newark.com/nte-electroni...-92/dp/29C5294
Hope that helps.
JonSnell is offline
Old 17th Jan 2021, 10:42 pm   #4
Bazz4CQJ
Bazz4CQJ's Avatar
attached are datasheets for a 2SK19, and my recollection is that the 19 was used in some FM tuners and is not too far away from the 23. I can pop a 19 in the post for you if you'd like to try it. I bought a few for a project some time ago.
B
Bazz4CQJ is offline
Old 18th Jan 2021, 12:39 am   #5
Ted Kendall
Thank you all - PM sent, Baz.
