Old 15th Jan 2020, 2:09 pm   #1
Krolroger
Default Dial Cord Beomaster 1400
Hello All,
I am trying to restring a Beomaster 1400 which will require a degree of patience.
So as I don't get it back to front as it were, can anyone tell me whether the vanes in the variable tuning cap should be fully meshed - or fully unmeshed - when the dial pointer is at the low end of the FM band (87 MHz)?
Counter-intuitively, the dial scale has the low numbers at the right hand end.
Many thanks,
Simon
Name:	BM1600 Tuning.jpg
Krolroger is offline   Reply With Quote
Old 15th Jan 2020, 9:56 pm   #2
Goldieoldie
Default Re: Dial Cord Beomaster 1400
Hi Simon,
At the lower frequency the v cap will be fully meshed
Pete
Goldieoldie is offline   Reply With Quote
Old 16th Jan 2020, 1:40 am   #3
Krolroger
Thanks, Pete
Old 20th Jan 2020, 12:43 am   #4
Krolroger
Hello,
I'm going slightly off topic here, but while going googly eyed figuring out how to restring my ancient Beomaster, I notice the set has been "got at" - quite neatly - which maybe suggests some sort of professional bodge.
There is a small square of very thin plywood separating two of the AM and FM tuning coils, and what look like thin veroboard inserts into the AM/FM detector coil.
Does anyone care to hazard a guess as to what might be going on here?
Haven't powered this up yet, as I'm not happy with the mains switch so I can't comment on functionality.
Old 20th Jan 2020, 8:14 am   #5
Nuvistor
Nuvistor's Avatar
The plywood between the cans could be forcing a bad joint to make contact, don’t know about the veroboard in the cans.
Frank
Nuvistor is offline   Reply With Quote
Old 20th Jan 2020, 11:28 am   #6
Krolroger
Thanks, Frank.
I will reflow them.
Simon
Old 20th Jan 2020, 1:27 pm   #7
Julesomega
Julesomega's Avatar
I don't know that set, but I recognise that the "IFT can" is a small daughter-board in a screening can, maybe the AM detector or something
- Julian
It's good here
Julesomega is offline   Reply With Quote
Old 20th Jan 2020, 2:29 pm   #8
Krolroger
Hi Julian,
So what I thought was a veroboard insert could be part of the daughter-board? It is indeed an FM/AM detector.
Interesting.
Thanks,
Simon
