Old 14th Jul 2019, 8:53 pm   #21
Reelman
Reelman's Avatar
Default Re: Philips N4450 Reel to Reel Tape Player
Originally Posted by TonyDuell View Post
I think at switch-on one of the 'direction' lamps should glow at low brightness showing the direction it was last used in.
Tony is absolutely right, on power on there should only be one of the two “play” lights on and dimmed. The stop button has no illumination.
Incidentally on power on both reels should rotate momentarily in opposite directions. This is to pick up any lack in the mounted tape.
Peter
Reelman is offline
Old 14th Jul 2019, 9:00 pm   #22
Michael Maurice
Michael Maurice's Avatar
I successfully repaired the flip flops on these using BC547’s and BC327’s.
The BC327’s have a similar current rating to the AC128’s and are pin for pin compatible
Forum Moderator
Michael Maurice is offline
Old 14th Jul 2019, 10:28 pm   #23
Sideband
Sideband's Avatar
The 'square PCB at an odd angle' sounds like the capstan motor electronics. It's mounted on the motor iteslf which drives the 2 capstans via a belt. I don't know if you are missing just the PCB or the complete motor assembly.
Yes that is correct.
It's actually part of the motor and was never available separately.
As an aside, some versions of the service manual give the circuit diagram for this part.
The 'Circuit Description' showed the circuits of the modules. It was available separately from the Service Manual which only showed the modules as blocks.
Sideband is online now
Old 14th Jul 2019, 11:12 pm   #24
julie_m
I'd have expected BC327s to be a good substitute in this application. I looked at the circuit and it only depends on the PNP polarity of the transistor, not the base-emitter voltage. The base-in-the-middle pinout makes it a very easy substitution.
A flip-flop fault could certainly cause your spurious recording lights problem. AC128s were once thought immune to Tin Whisker Syndrome, but apparently it just takes longer to show. Better to whip the lot out now than store up trouble for later.
As for why Philips used a germanium transistor: They were still making them in the 1970s, and they probably were cheaper than a similarly-rated silicon PNP transistor (it's harder to dope silicon to P-type than N-type; germanium is the opposite).
julie_m is offline
Old 15th Jul 2019, 7:45 am   #25
Ray_Singh
Thank you experts. I have noted the transistors you have mentioned and have seen that these are under £2 delivered via ebay.
There are lots of spares available on Ebay today - even a capstan motor board....
https://www.ebay.co.uk/sch/i.html?_f...N4450&_sacat=0
Ray_Singh is offline
Old 15th Jul 2019, 8:58 am   #26
Ray_Singh
Peter
Thanks Peter - Yes, I initially found this odd that on power up the reels rotated in opposite directions, but now understand why. Machine 1 does this.
Old 15th Jul 2019, 4:31 pm   #27
Ray_Singh
Sorry for all the questions - but If i want the machine to run properly and i want to try and fix it myself, where should I start?
I guess that replacing all the common fault transistors is a good place to start.
Replace all AC128s with BC327's
Replace all xxxx with BC 547's
Anything else?
My:
flip flops have BC147's.
tape tension is BC 147's.
auto rev is 157's and BC547
motor stop is BC557 BC547
Old 15th Jul 2019, 9:53 pm   #28
Michael Maurice
My advice is to replace the AC128’s with BC327’s then test everything. By and large the BC147’s will be ok but if you suspect them, fit BC547’s.
I would not attempt to replace transistors for the sake of it. The AC128’s are known troublemakers but the rest are not and you might end up with more problems than when you started.
Forum Moderator
Old 16th Jul 2019, 7:22 am   #29
Ray_Singh
Sorry Michael. On which board are the AC128's? I cant see them, but i do need some new glasses.....
Old 16th Jul 2019, 8:54 am   #30
Michael Maurice
They are on the flip flop boards, there are 4 on each board and are recognisable by their metal can.
Forum Moderator
Old 17th Jul 2019, 7:57 pm   #31
Ray_Singh
BC 327's ordered and will arrive on Friday - 20pcs for £3.98 delivered...
Apologies for external linked images, but what is missing here?
[img]https://i.**********/yUk9J8G.jpg[/img]
Do i need this part?
https://www.ebay.co.uk/itm/PHILIPS-N...2329%7Ciid%3A1
https://i.ebayimg.com/images/g/oXUAA...GX/s-l1600.jpg
Old 18th Jul 2019, 10:48 am   #32
Ray_Singh
BC 327s have arrived and I am keen to get on and replace.
The AC128 data sheets i have shown that the component should have a tab on the metal case. Mine dont.
Is the red spot (or black spot on some of them) marking the emitter?
Old 18th Jul 2019, 2:27 pm   #33
Sideband
Sideband's Avatar
All the AC128's I've ever seen don't have a tab and the red spot marks the collector. The AC127...the NPN counterpart has a dark blue spot that marks collector
Old 18th Jul 2019, 5:45 pm   #34
Ray_Singh
Thanks Sideband - If im feeling brave, I will try to replace all 8 across two machines tomorrow (16 in total).
Some of mine have a blue dot. Does that mean that they are NPN and cannot be replaced by the BC327s?
Old 18th Jul 2019, 7:43 pm   #35
Sideband
Sideband's Avatar
Well.....if they are marked AC128 then they should be OK. If they are originals as fitted by Philips then they will be AC128.
The original flip flops had AC128 and BC148 (or BC548) fitted so PNP germanium and NPN silicon. NEVER NPN germanium.
Why not post a picture of one of your flip flops?
Old 19th Jul 2019, 7:52 am   #36
Michael Maurice
I have had some AC128's that have a slightly thinner can and a tab, a bit like an elongated BC107.
Forum Moderator
Old 19th Jul 2019, 9:56 am   #37
Ray_Singh
Thank you.
Flip Flop photo:
[img]https://i.**********/kkacDvx.jpg[/img]
Name:	N4450 flip flop.jpg
Last edited by Michael Maurice; 19th Jul 2019 at 1:48 pm. Reason: addition of picture
Old 19th Jul 2019, 7:24 pm   #38
Sideband
Sideband's Avatar
Yes...the AC128's as I remember them....red spot marks collector. If you are not aware, those BC147 lockfits are now becoming unreliable.....They can be replaced directly by BC547 which is the same transistor in a different package, also has the same lead configuration. Chances are almost any NPN transistor with a similar gain could be used but watch the lead configuration.
Old 20th Jul 2019, 4:37 pm   #39
Ray_Singh
Thanks Sideband.
I spent a bit of time fiddling with the machine today. I swapped the flip flop boards around between machine 1 and machine 2 and from top to bottom.
I finally got the record button to switch off and the old tapes i have are actually playing!! I cant hear them as i have no DIN connectors, but i can see the VU meters fluctuating!
I am so excited.
I will use the "spare" flip flop boards as a starting point to swap out the AC128s to BC327s and see how i go from there.
The capstan motor will be here next week too!
Old 22nd Jul 2019, 11:42 am   #40
Ray_Singh
Capstan motor arrived.
I have managed to hear the tape playing from machine 1. I dont have any of the odd speaker connectors, so plugged in a DIN from the monitor output into my own home amplifier. I can hear tapes i recorded 25 years ago!
I managed to screw up the power on/off switch on both machines. Does anyone have spare please?
