20th Oct 2011, 4:13 pm | #1 |
c. 1973 Hacker RP38A Hunter VHF 12 transistor AM/FM portable
Hello again,
I acquired this Hacker Hunter VHF at the last Tonbridge Audiojumble event for not a lot considering it is in exceptionally nice cosmetic condition and complete with its original box. It didn't work at all though, not a peep. The RP38A Hunter had at least three facelifts during its long production run which commenced in 1970 as the Hunter VHF, originally it had a drilled soft aluminium grille and a rounded aluminium handle, it was then fitted with a much improved slatted cast alloy grille, it was then renamed the Hunter FM/AM and was eventually fitted with a square handle. This mid production example serial number 51142 has a rounded handle and the later grille. I have examples of all the Hunters and keep loads of spares for them and they remain my favorite Hacker transistor portable. Ron Bryan very kindly did most of the internal work on this one. Even though it was silent it was found to be taking 20mA at minimum volume so it was trying to do something. The loudspeaker was checked first and it was found to be open circuit, so another loudspeaker was attached and away it went. An original loudspeaker from a scrap Hunter was then fitted, pots and switches cleaned with DeoxiT, the quiescent current and mid point voltage adjusted and MW and LW were realigned and this Hunter was working well again. It came back to me to be cleaned and completed. One battery clip was damaged so that was replaced with an original, the switched volume potentiometer had been replaced but when switched off, the pointer on the knob was pointing in the wrong direction so I replaced that with an original pot. Lastly I realigned FM (RF) as it was slightly out of adjustment. The case just needed a light clean and polish. So another excellent Hunter to add to my Hacker collection. If you haven't encountered a Hunter RP38A then try one, you will be impressed with its performance, its build quality and its excellent sound quality. We have another Hunter in theatre at the moment, which is needing rather more restoration work done to it. I'll add its write up to the thread when it's finished. My thanks to Ron for his help. Howard Last edited by howard; 20th Oct 2011 at 4:19 pm. |
21st Oct 2011, 8:37 am | #2 |
Re: c. 1973 Hacker RP38A Hunter VHF 12 transistor AM/FM portable
Hi Howard,
The very last ones had black plastic tone control knobs - have you got one of those? Like you, I have examples from each production phase, but the black knob version is still missing from my collection. And because these sets fetch such high prices on the open market, I'm biding my time until I see a bargain one... Very nice job Mark |
21st Oct 2011, 9:12 am | #3 |
Nice one Howard. I also feel these are my favourite Hackers, more compact than the SovII but with similar internals, I particularly like the oak side cheeks. I use one in my kitchen now, in preference to a Bose Wave radio, solid wood beats plastic hands down.
Neil
21st Oct 2011, 9:29 am | #4 |
I used to have one, badged as a Hunter VHF, but it didn't have the wooden end cheeks, it was black rexine all over like my Sovereign II. It only had a tone control, not treble and bass, must have been a really early one. Your one looks superb Howard!
21st Oct 2011, 10:50 am | #5 | ||
No I don't have the variant with the black knobs yet. Hunters do command a good price on Ebay and elsewhere and rightly so, they are undoubtedly amongst the best transistor radios ever built in the UK. This one was £15, still a lot for a non working set I guess. Quote:
I don't have an all black RP38A but I do have a couple of the earlier RP38 Hunters in that finish. I suspect with the single tone control that yours is the earlier model too. I think the earlier RP38s had the wood effect fablon strip in the handle as well, I'm not so sure that the RP38As had that. A pic of the two switched potentiometers below, the one on the left is the correct one with the locating tab on the right hand side of the spindle. They are in fact identical except for the locating tab which is 180 degress out on the replacement. It will be recycled as it's almost new, simply by carefully lifting the four bent over tabs securing its top plate which can then be turned around. Howard Last edited by howard; 21st Oct 2011 at 11:01 am. |
21st Oct 2011, 12:31 pm | #6 |
Now you come to mention it Howard it was a plain vanilla RP38, not an RP38A. One day I will have an RP38A as I love the styling and it would nestle nicely amongst the Roberts sets I have here!
21st Oct 2011, 2:02 pm | #7 |
That's right; single tone control = RP38, bass and treble = RP38A
The RP38 was available in all black, or black and wood. On a brochure somewhere on the Hacker Radio Yahoo group, the differences are listed (IIRC, the wooden version was an RP38T). As to the fake wood strip in the handle, I'm not sure that was fitted to all, but I certainly have one in my RP38. The earlier RP38A, the ones with the mesh grill, were also available in all-black and with wooden sides. They also had some green print on the tuning scale - rather nicer than the all-white later models in some ways. Apart from the very earliest RP38s, they all had that Elac loudspeaker, which is largely responsible for the superb audio performance. The RP38 had a simpler amplifier (the amplifier in the RP38A is electrically equivalent to the Sovereign II), but still sounds very good indeed. Of course, the later sets had a DC input socket. This came in at some point in the RP38A with mesh grill run - meaning that all sets with the extruded "bar" grill should have it. Saves a few pennies in battery costs Glad to see the Hunter is still causing interest; I haven't bothered posting my restores because I thought they were a passe now. Will think about posting some when I've more time... Cheers, Mark |
23rd Oct 2011, 8:11 pm | #8 |
Nice one Howard. Love these radios. Some say they are better than the Sovereign. I have one of these on my large to do pile.
Simon BVWS member |
23rd Nov 2011, 6:45 pm | #9 |
Nice write up Howard. Some say they're the best sounding portables of their size. Good luck with the next one
All the very best, Tas |
24th Nov 2011, 3:04 pm | #10 |
Nice one Howard, a really nice good example you have here.
Simon BVWS member |
24th Nov 2011, 5:04 pm | #11 | |
The Hunters are my favorite British transistor AM/FM portable radios, I always have one out in my living room. The other Hunter is finished now and is looking as good as this one. Ron is likewise impressed with the Hunters and has kept it. It took a lot of work to get it working properly and to restore it though, write up coming shortly. Howard PS I see that a Hunter was chosen as a prop in the Inspector Morse TV series. Last edited by howard; 24th Nov 2011 at 5:16 pm. |
24th Nov 2011, 8:39 pm | #12 |
24th Nov 2011, 9:24 pm | #13 | |
John |
25th Nov 2011, 9:23 am | #14 |
Hi John,
That's very unusual indeed. I wonder if the black has somehow faded (although it seems unlikely that it would have faded uniformly). Perhaps it's been re-covered? Or maybe it was a limited edition or custom version for some reason? A friend of mine has changed the colour of sets in the past by using vinyl treatments - leaning aside the question of originality, I must say the results were very good indeed. As an aside, a good friend and colleague tells me that he has a navy blue Sovereign II, although I haven't seen it myself yet (he's recently unearthed it - his workshop is rather full, so hopefully soon). Pictures would be good if possible - I can also add them to the picture library at the Hacker Radio group... (Perhaps the mods might start a new thread if that's deemed best.) All the best, Mark |
