View Poll Results: Will the radio work when turned on at 4PM? | |||
YES | 2 | 10.00% | |
NO | 18 | 90.00% | |
Voters: 20. You may not vote on this poll |
14th Nov 2021, 5:49 pm | #161 | |
Re: Pilot Little Maestro restoration project.
Frustrating having to wait on another dropper cap coming in the post Out of desperation i paid 50p extra for first class postage Cheers Jay
Help!! I've been electrocuted by a glass thing that glows |
14th Nov 2021, 6:30 pm | #162 |
Hi Jay, if you can achieve 75volts at the top of the heater chain, then everything will be in order. In fact spot on if the dial light is a 6.3 volt bulb.
Assume the valve line-up is 6A8G alt 6K8G, 6K7G alt 6U7G, 6Q7G, 25A6 or alt 25L6 and 25Z6. DFWB. Last edited by FERNSEH; 14th Nov 2021 at 6:39 pm. |
14th Nov 2021, 6:34 pm | #163 | |
If i get close i'll be happy Cheers
14th Nov 2021, 6:56 pm | #164 |
In reality, a few volts either way for the heater supply won't make a lot of difference. Remember when these sets were built, they didn't have a mains voltage tap and were rated 200 - 250V without adjustment. At the low end of mains, the valves would have been under run. At 240 - 250V, they would have been running normally. it's likely that for 90% of their use, the valves would have been slightly under run.
14th Nov 2021, 7:32 pm | #165 | |
Jay
14th Nov 2021, 7:57 pm | #166 |
Does anybody think this will actually work first time when the heaters & HT Supply is sorted out ?
14th Nov 2021, 8:59 pm | #167 |
Probably a very high chance of success; worst case it will only damage 1 valve but without one of us testing it we have no way of knowing.
You could try running on a lamp limiter or variac at reduced voltage. Measure heater string volts and then volts into set. They should be in the proportion of 75/240 of whatever voltage you are applying Ed |
14th Nov 2021, 9:09 pm | #168 | |
If the valves are good and theres no coils/inductors open or shorted, Then it should sing again. Just found a red 60w bayonet bulb, The type for a log effect fire and a 100w screw in, But no socket for it. Jay
Help!! I've been electrocuted by a glass thing that glows Last edited by Radio Scotland; 14th Nov 2021 at 9:36 pm. Reason: Additional info |
14th Nov 2021, 9:45 pm | #169 |
I've just been in the 'mancave' and tried the Pilot Model 10 that I converted to capacitor dropper around 12 years ago. All still good so I thought I'd show you how I did mine. I used a capacitor from an old florescent fitting which was a 2.6uF at 400Vac which was pretty much spot on for the value I needed. When I measured it however is was slightly low at 2.4uF. When fitted, the radio worked well but was a tad low on heater voltage so I fitted a couple of 0.1uF caps in parallel and put them in parallel with the 2.6uF to bring the value up and I was happy with the result. I subsequently replaced the two 0.1uF caps with a single 0.22uF cap at 300Vac which fitted much more neatly into the available space.
I used the original dropper mounting cage with some shrink-sleeving which made a snug fit into the space. Well it's been OK for the last 12 years with moderate use. The last one just shows the mains voltage at the time which is a tad under 240V.
There are lots of brilliant keyboard players and then there is Rick Wakeman..... Last edited by Sideband; 14th Nov 2021 at 9:55 pm. |
14th Nov 2021, 9:59 pm | #170 | |
Like i say iv'e never worked on a valve set before or really done any restoration work on a radio, But learning plenty from this thread, Does anybody know the working wattage of this radio ? I'm thinking around 40 watts. Cheers
14th Nov 2021, 11:12 pm | #171 |
Well unless it's stated in any of the service literature or (sometimes) printed on the back of the radio, then 40W is a fair guess. Your set uses 300mA valve heaters whereas mine uses 150mA heaters. According to my power meter mine is running at around 28W so I suppose if you were to double that to 56W it probably won't be far out.
14th Nov 2021, 11:17 pm | #172 | |
Jay
15th Nov 2021, 2:51 pm | #173 |
Trying to find small enough bolts to mount the HT Resistor isn't easy
Its a job for the dremel
15th Nov 2021, 5:50 pm | #174 |
''Bodged in''
15th Nov 2021, 7:26 pm | #175 |
I'm confused. In the pic below is the way the rectifier socket is wired, White wire is the anodes, Piece of solder is the cathodes. I Have a 25Z4G Rectifier, Radio calls for a 25Z6G.
But the socket doesn't looked as if its wired for either of them, I'm probably missing the obvious, Been a long day. Jay
15th Nov 2021, 7:35 pm | #176 |
The socket in the photo is wired for either so far as I can make out, 3&5 are connected together (anode(s)) and 8&4 are connected together (cathode(s)) Numbered anticlockwise in the socket photo starting with number 1 which is the first to the right of the keyway for the spigot, the first to the left of the keyway being number 8.
Lawrence. Last edited by ms660; 15th Nov 2021 at 7:46 pm. Reason: extra info |
15th Nov 2021, 7:48 pm | #177 | |
Thanks Jay
15th Nov 2021, 8:08 pm | #178 |
Some of the side contact valves were numbered anticlockwise as viewed from underneath, eg:
https://frank.pocnet.net/sheets/030/e/ECH3.pdf Lawrence. |
15th Nov 2021, 8:41 pm | #179 | |
I have a metal temperature probe on my DMM,Was wondering if i could use it to monitor the temp of the HT resistor ? Keeping in mind chassis is hooked to neutral.. Jay
15th Nov 2021, 8:51 pm | #180 |
