View Poll Results: Will the radio work when turned on at 4PM? | |||
YES | 2 | 10.00% | |
NO | 18 | 90.00% | |
Voters: 20. You may not vote on this poll |
12th Nov 2021, 1:31 pm | #121 |
Re: Pilot Little Maestro restoration project.
New tone correction capacitor fitted, Dropper caps in parallel come out around 3.8UF So i'm either gonna be low on voltage or high and they're to big to fit on the valve base, Plan B i suppose, Mounted on the old smoothing can space.
Still waiting on the bleed resistor, So nothing being fired up yet
Help!! I've been electrocuted by a glass thing that glows Last edited by Radio Scotland; 12th Nov 2021 at 1:36 pm. Reason: Extra info |
12th Nov 2021, 3:15 pm | #122 |
Quick summary of the work done today for anybody that's interested.
Built cap dropper ''block'' 2 X 2.2uf safety caps in parallel, Working voltage 305 Volts, Actual capacitance measured in pic below. Across the line cap replaced with an X2 ...275 Volts rating. Tone correction cap replaced.. Thats it for today, No bleed resistor yet.. Any mistakes feel free to comment Cheers jay
Help!! I've been electrocuted by a glass thing that glows |
12th Nov 2021, 4:56 pm | #123 |
Dropper too near rectifier valve ? Heat shield needed ?
12th Nov 2021, 5:30 pm | #124 |
12th Nov 2021, 6:13 pm | #125 |
Wasn't happy so i moved it farther way..
12th Nov 2021, 9:15 pm | #126 |
Any boffins out there that can tell me what voltage 3.8uf of capacitance will give me on the heaters ?
12th Nov 2021, 9:24 pm | #127 |
12th Nov 2021, 9:27 pm | #128 | |
Read about guys having no issues using a 4uf (Stated value) motor run cap..
12th Nov 2021, 9:46 pm | #129 |
Measure the voltage. Start with a lower capacitance and then increase it if necessary.
Valve heaters are quite tolerant of being run slightly over voltage, though obviously it's not desirable. |
12th Nov 2021, 9:49 pm | #130 | |
Jay
13th Nov 2021, 1:20 pm | #131 |
Well plugged it in, No bangs or blue flames, But no heaters or lamp either, And 240v on the output of the dropper, Kinda like there was no load on it, Checked the heaters and they're ok, Maybe a break in the chain some where.
13th Nov 2021, 2:30 pm | #132 |
Turned out one of the valve heater pins was needing tightened up, 56 VOLTS output from the dropper and a rather dim dial lamp
More capacitance on the dropper ? Well its a start.. Jay
13th Nov 2021, 5:48 pm | #133 |
hello all. if you have a surge limit resistor in the heater chain, possibly reduce its value ?
dave |
13th Nov 2021, 5:51 pm | #134 | |
Jay
13th Nov 2021, 5:55 pm | #135 |
I'm missing something
13th Nov 2021, 6:36 pm | #136 |
hello all . thats strange,what voltage have you got going into the cap dropper
? is dial bulb in series with heater string ? dave |
13th Nov 2021, 6:42 pm | #137 | |
I wonder if the 100k bleed resistor is the wrong value and its loading the voltage down Jay
13th Nov 2021, 6:48 pm | #138 |
hello all , try to disconnect bleed resistor, it should still work BUT give things
time for cap discharge, before touching set after switch off dave |
13th Nov 2021, 6:51 pm | #139 | |
Cheers jay
13th Nov 2021, 7:42 pm | #140 |
Hi Jay, note that in this setup Vmains does not equal Vcap + Vhtrs. It is actually what is called a vector sum and takes a while to explain and get your head round
Ed |
