25th May 2019, 2:43 am | #41 |
Re: Who's still using their old Safebloc?
I've got one I haven't used for years which is used very occasionally. Still wouldn't be without it though.
Regards, Paul
...No, it's not supposed to pick up the World Service, it's not a radio! |
25th May 2019, 8:36 am | #42 |
Hello.
It is a long time since I last used the one I have. It is red and has RS on the the Top. Kevin |
25th May 2019, 9:00 pm | #43 | ||
Well, I’ve found it and had a look.... the neon in mine is wired between line & neutral, and appears to be original without any sign of modification. I wonder if they changed the spec during its production run? Interesting...... It was manufactured by ‘Cybernaut Controls’ of Kent, but I can’t find any information on this company.
The honesty of imperfection.......... Last edited by thermionic; 25th May 2019 at 9:07 pm. Reason: Extra info |
25th May 2019, 9:12 pm | #44 |
I'm certainly still using mine, plus the less safe home made version as can be seen in the photo. The cheap rubber plugs fitted to them both at the time are not ideal, and the one on the home made block has the insert pulled out of the base, hence the remains of the red tape which used to hold it together. Latterly, I found it more useful to have it with a quick removable plug top for quick fuse changing (I blew quite a few), the plug top doesn't pull completely off when removing it from the socket due to it being of the type that the cable has to be threaded through before connecting to the plug terminals. Having something like this is NOT to be recommended to others on safety grounds - it's a case of "do as I say", and not as I do! Also, the toggle switch has had its contacts welded permanently in the 'on' position due to something going 'bang' (probably more than a few times) on switch on many years ago...I ought to get round to replacing that switch some time, and the plug, I hear you say!
It also seems that I still have the original box for the proper Safeblock. This has survived due to it being used as a box to keep a lot of random diodes and bridge rectifiers in - there's a paper label stuck on the top of it with Sellotape indicating its contents, the tape having now aged will probably come off quite easily now, thus leaving the box as original should I want to keep it as a collectors item The white ribbed cable on both of them came from the same drum, possibly sometime in the early to mid 70s. Notice how mucky the cable is on the home made 'danger-block' compared to the same cable on the Safeblock, that has to tell you something about which one has had the most use over the years |
25th May 2019, 11:05 pm | #45 |
Hi
I bought my Safebloc from RS back in the early 1980s and in the past it had regular use but is still used occasionally these days and I find it very useful. I haven't mounted mine to the bench, it is just connected via 3 core cable to a 13A plug. I periodically remove the base cover to inspect the connections and cord grip and so far no problems. I've also acquired a NOS one from the local car boot for £1, I'll probably mount that to the bench once I've rebuilt my workshop. Regards, Symon |
25th May 2019, 11:13 pm | #46 |
Great bit of kit and use mine a lot.
A word of caution. If mounted as mine is on the front of the bench, it is only too easy to close the door while working on the chassis. I have done this a number of times fortunately without receiving a shock! The same applies if mounted on the bench top. The lid can snap shut. Always open it up fully to lessen the risk. I also admit to owning and using those lovely crocodile clips with a Clix plug on the end .. Very useful for overriding mains switches etc and connecting odd receiver connectors to the mains. Of course you have to wear your sensible hat while using. I also have a high regard for the 5amp Clix plug. Good solid contact and can be yanked out in a second should anything start to overheat. John. |
26th May 2019, 5:25 am | #47 |
Cables with mains plug to croc-clips were generally called 'suicide leads' at one place I worked. Very useful, but you had to hide them when the safety officer was doing his checks (FWIW he knew they existed but couldn't oficially complain about them if he didn't see them...)
A friend of mine made his own safebloc-a-like using croc-clips fixed inside a sliding-lid wooden box (I think originally a cigar box). He fitted a double pole switch to isolate said clips and the clever part was he arranged things so that the lid could only be sild open if the switch was off. It woudn't pass an offiical safety inspection but it was a bit safer than a lot of such things. |
26th May 2019, 8:37 am | #48 | |
I didn't get to use a Safebloc until I started working for Philips in Purley Way a few years later and marvelled at their simplicity and function. Naturally the Philips workshop complied with and exceeded current safety standards and all benches also had the wonder of the isolation transformer...something else that had been lacking in my previous job.
There are lots of brilliant keyboard players and then there is Rick Wakeman..... Last edited by Sideband; 26th May 2019 at 8:42 am. |
26th May 2019, 10:44 am | #49 |
I’ve got 3 original style Safeblocks one must date back to the late 50’s/early 60’s. The bottom cover got smashed after about 2 years and replaced with stout cardboard which is still there. I have a collection of odd leads to fit a variety of radios, TV and hifi without mains plugs so I use the Safeblocks to connect them.
26th May 2019, 11:25 am | #50 |
I have never understood why they bothered with that thin backing plate.
They aught to have just put an instruction to screw them down. Both of mine have been screwed to bits of wood from when I acquired them. |
26th May 2019, 1:13 pm | #51 |
one of my safeblocks the one in use has the pin in the hinge removed so the cover can be removed so cannot be closed by accident no chances taken here Mick
26th May 2019, 1:37 pm | #52 |
Hi yes ive got a safeblock although mine hasn't got a neon lamp on it its is definitely one of the most useful things to have as its easy to test stuff as others have said. I use mine via an RCD just in case its better to be safe than sorry. The lid on mine wont fully close unless given a definite push which is also a good thing
26th May 2019, 2:21 pm | #53 |
I have a couple of Safeblocs from my old days at Rumbelows when we used them to wire multiple TVs and videos for demonstration.
I occasionally use one to test out bits n bobs . |
26th May 2019, 5:13 pm | #54 |
I still use my faithfull old Safeboc, now mounted on a wooden block as part of a lamp limiter.
Peter |
26th May 2019, 5:20 pm | #55 |
My old Bakelite one still comes out occasionally although I tend to fit plugs more often now than I did in the past.
Chris |
24th Jun 2019, 11:02 am | #56 |
Hello yes I have two of these, one as the Keynector version and the other is by Rendar I believe. One is permanently connected to a 1 kVA Isolating transformer, just makes mains fault finding a little safer, and the other for general use. Whoever thought them up had a great idea they must have been about since the late 60's as I remember using one, also with a repaired cover, as an apprentice with the Ever Ready Company in East London.
24th Jun 2019, 2:55 pm | #57 |
Bull’s Electrical of Croydon and later Hove produced a kit in the 80s to make a form of “Safeblock”. Used a microswitch to remove power when making connections but was easy to override by accident. Still got mine somewhere. Anybody else build one?
Peter |
24th Jun 2019, 6:55 pm | #58 |
One of mine was used yesterday.
24th Jun 2019, 7:41 pm | #59 |
Has anyone seen one of these? The only identification on the moulding is: TG13533 MK-2. Telephone, military?
It is a 2amp 3pin plug with easy connect push button wire retainers. [No earth] John. |
24th Jun 2019, 10:34 pm | #60 |
Yes, see my homemade one along with the proper one shown back in post #44.
Below is a photo I've just this minute taken of my homemade one in use with a couple of test leads supplying mains to the rear connectors of a Rigonda radiogram that's in for repair. It's easier to do it this way as the proper mains connector comes off with the back panel on these. I could use bare ended wires with croc clips on the other to fit in the proper Safebloc, but I already have test leads with 4mm plugs on one end and croc clips on the other for use with Avometers etc., so I always use these and the terminal block for jobs like this. I do often stick a bit of cardboard between and over them to prevent shorts from them being pulled together while I'm working. |
